what shift rod for b series crx?
What do you mean would you be talking about the selector shaft that the linkage connects to allowing you to shift gears or what. Be more specific in order for someone to help. Slot of people call different parts different names
you need the shift linkage from a 90-93 integra. both the shifter rod, and the stabilizer bar. there are lots of write-ups that will tell you exactly how to modify them to fit.
basically you're cutting a section out of each one so they'll fit the shorter CRX body. but my advice is don't just cut based on what the write-up says. measure for yourself. i did it myself without measuring first, and it turned out i needed to take a whole extra inch out of each piece to have it fit correctly. (i suspect because my offbrand engine mounts).
make sure that when you reconnect the pieces (after shortening each one) that they DO NOT BECOME MISALIGNED. draw/scratch in a reference line or it will be all fuct up.
it's also a nice opportunity to position the shifter where you want it to be more comfortable for you. i'm tall so i have the shifter tilting back.....don't have to reach so far anymore
go on ebay they have the hasport ones on there. i bought mine for my b16a for like 115 shipped brand new. it sucks to cut and weld them back together
streetsold6teeny8
18
Jun 29, 2009 10:18 PM
supracrx
Northern California (Sales)
18
Mar 14, 2006 06:48 PM
thecorey
Oct 21, 2002 11:01 PM
