Type S intake manifold any good??
Old Dec 25, 2008 | 07:37 PM
oneprelude's Avatar
Default Type S intake manifold any good??
I have a Type S engine and I'm planning to get a Euro R im. I noticed that the throttle body of a Type S is bigger than my H22A4 throttle body, so is it any better? Is there a difference between the two (base vs Type S)? And should I get a Euro im? THanks
Old Dec 26, 2008 | 02:02 PM
HdeucedeuceA's Avatar
Default Re: Type S intake manifold any good??
First off, the Type S manifold is basically the same as all of the other H22 manifolds. So yes, get the Euro R. Do you know what it takes to put the Euro R on? It's not just a bolt on affair; it is but it's not.
Second, all H22's use a 60mm throttle body. Except for the Type S and Euro R, which use a 62mm.
Before you put the manifold on decide on what size throttle body to run. Then have the manifold port matched to it. My .02
Old Dec 26, 2008 | 05:19 PM
oneprelude's Avatar
what do you think is the best throttle body size for the best performance?
Old Dec 26, 2008 | 07:14 PM
92civlude's Avatar
Yeah, the Type S is the same manifold. Except its the runners are polished a bit more. The skunk2 intake is an easier install than the Euro-r. And if given the choice between a 60mm TB and 62mm, go with the 62
Old Dec 27, 2008 | 04:24 PM
kingh90's Avatar
aem v2 just my .02 cents
Old Dec 27, 2008 | 04:34 PM
oneprelude's Avatar
I was expecting something bigger
Old Dec 27, 2008 | 05:25 PM
InvaderTrax's Avatar
We're talking manifolds not intake pipes
Anyway, the Type S is a regular H22 manifold that's hand polished and has a slightly bigger TB. If you've got the money and feel like doing the mods to install it, go Euro R. And I'm sure you could get a few $$ for your old Type S manifold when you're done
Old Dec 27, 2008 | 06:24 PM
92SR4WS's Avatar
LOL
Most people run a 68mm or 70 mm TB from what I've seen
Old Dec 31, 2008 | 02:53 PM
oneprelude's Avatar
i measured my throttle body and it's 66mm
Old Dec 31, 2008 | 03:53 PM
Storm_Rider's Avatar
what did you use to measure it and did you take the ID or OD?
Old Jan 1, 2009 | 02:36 AM
ethereal2pt2's Avatar
this one made me lol.
Old Jan 1, 2009 | 07:17 AM
oneprelude's Avatar
I believe ID is for inside diameter, so from the inside it has a length of 2-9/16 inches, which is approximately 65.0875mm
Old Jan 1, 2009 | 10:40 PM
I have a Professional Products 68mm with my Euro R manifold. There was a noticable power increase with the TB and Euro R install and I'm untuned.
As far as what size is best. I've seen no real proof of which size is best. I have read people saying that H22's needs big throttle bodies. I've also read that throttle body size is dictated by the plenum volume of the manifold; small plenum should get a big throttle body and vise versa.
You should also note that a bigger throttle body will give you better throttle response. Some people even say it's more like an on/off switch. With my 68mm it is noticable that I'm not on the gas as much as I used to be with my OEM 60mm. 3/4 throttle to full throttle their isn't as much of a power increase. Although, the fact that I'm untuned has to be factored in.
Also, for an intake, go with a 3" cold air intake with a BPi flow stack. Blake has a dyno compairison and the results were great.
SiRocket02
14
Oct 14, 2010 08:28 PM
CivicSi95
Sep 20, 2009 12:23 PM
EG5Boy
Dec 22, 2006 06:41 PM
TEAM562racing
May 9, 2004 08:28 AM
tyflip2
Jul 18, 2003 07:28 PM
