piston question....
Old Dec 25, 2008 | 05:05 PM
cjmurillo's Avatar
Default piston question....
will a piston off of an f23 fit on an f22 rod?......
Old Dec 25, 2008 | 05:56 PM
sfcd5's Avatar
Default Re: piston question....
no
Old Dec 25, 2008 | 08:40 PM
P_Adams's Avatar
Both pistons sport the same piston pin diameter at .866", so it may actually fit THE ROD.
Now the question becomes dome volume and compression height?
The f23 piston is 1mm larger in diameter.
An easier route would be a set of aftermarket slugs machined for what you want, and the application you have.
P
Farmer89511
Nov 14, 2008 11:51 AM
CO_CReX
Oct 5, 2006 09:08 AM
TURBODC4TEG
Jul 19, 2006 06:21 AM
gregsr
Aug 17, 2003 01:49 PM
