what motor is this?
hey i just picked up a 91 si and the guy put a new motor in. he said the new motor came shipped from japan. i kno its a d-series but its stamped with a "ZC" and nothing else. is this a d16a6 or something else?
yep pretty much. there not bad engines really. the a6 is fairly "zippy" for a non-vtec sohc, and the jdm zc has a little bit more oomph to it in comparison, so really its not a terrible engine to tool around with. till you can find something quicker that is.. and with 2 cams
Good ol' SOHC ZC, the Japanese economy engine that's still better than our top-of-the-line selection. As far as I know, it's identical to the D16A6 but with a different cam. I have one in my hatch and I'm interested in finding more info on it.
Different ECU really? I wonder what ECU is in my Si...
Originally Posted by acmoc
the sohc zc is the Japanese d16, it has a different cam and ecu good for about 118 hp.
Okay, but your admitting that they are different. Where's your proof? Where would the extra 1o hp come from then, everything else is the same.
http://www.hondacarforum.com/honda-2...cam-specs.html
http://en.wikipedia.org/wiki/Honda_D_engine
Hmotors is wrong already, 88-91 zc is a different motor then the 92-95 zc, this one has vtec.
^^ Exactly true.
A6 intake 227.5, ZC intake 233
A6 exhaust 194.5, ZC exhaust 196
Funny thing. I had an D16A6 stock in a 1990 crx Si last year, and decided to swap it in favor of a sohc mpfi cam from another engine i had sitting around. First off, there is definitely a difference in the way the cams perform. I liked the original A6 cam better though. It had more low end power and seemed more torquey.
The zc cam made more power on the top end, it was kind of peaky.....i didn't care for it.
I changed nothing else in the car.
So 10hp comes from that minor difference?
Also, I don't understand why the lift starts, ends, and peak are exactly the same, but the "actual lift" is different. Could just be my ignorance of cams. I'd like to get a full explanation though.
i thought that was odd too, but like you i also lack the understanding of how that is possible lol.
its also the use of the higher octane fuel they use there, as well as the fact the ecu would have a slightly different program.
Remember, i mentioned that the extra hp, it only at the very top end of the rpm range....a little blip to bump up the number imo.
The ECU mapping makes sense though. What's the SOHC ZC ECU? I haven't pulled back my carpet to check, but I have an inkling that I'm using the stock 1991 D16A6 ECU (PM6?).
Higher octane has nothing to do with it, the compression isn't nearly high enough. Furthermore, I always run my ZC on 87; when I put 89 in, I had a noticeable loss in power, especially at high revs.
# PG7 : 86-89 Integra (86-87 vac advance, 88-89 electronic advance)
# PM5 : 88-91 Civic/CRX DX
# PM6 : 88-91 Civic/CRX SOHC Si
# PM7 : 89-91 DOHC ZC (JDM 'EF' ECU)
# PM8 : 88-91 CRX HF
# PR2 : 89-91 ZC (Euro)
# PR3 : 89-91 JDM B16A EF8/9
http://www.hondata.com/techecuid.html
Less power? Hmmm, i had the great performance with the better fuel running the engine. Back in the day when i had a zc, it also ran an nos system, i could punch off high 13 second 1/4 mile times in my crx.
oh ok cool. alright i've been reading through a lot of forums about the sohc no-vtec zc, and i have one question. how much hp does is give to the clutch? i've seen people say 108. i've seen 118. one guy even said it gives 130! (i dont believe 130 ;]) so can someone please tell me the facts? haha thanks a lot!
The d16a6 has 108 hp.
The sohc zc non vtec has 118
The dohc zc, which is the d16a1 offered in edm crx's is the one with 130 hp. This has no vtec.
