Help Please - 93 accord Ex - Auto
Old Dec 24, 2008 | 12:31 PM
zspy_007's Avatar
Default Help Please - 93 accord Ex - Auto
Hi all,
I have a 93 accord Ex, auto.
When engine is cold, I put car in "D" and i feel some major jurking.
When i pull out after a complete stop, i feel some steel to steel tapping.
my guess would be some engine and transmission mount - both
Where are the engine mounts located?
Where are the transmission mounts located?
Anyone can provide me with a diagram or picture?
Thank you all
Old Dec 25, 2008 | 05:22 PM
zspy_007's Avatar
Default anyone???
anyone???
Old Dec 25, 2008 | 08:45 PM
P_Adams's Avatar
Default Re: Help Please - 93 accord Ex - Auto
Originally Posted by zspy_007
Hi all,
Thank you all
Here you go:
http://www.hondaautomotiveparts.com/...5=ENGINE+MOUNT
Left, Right, Front Upper and Rear Lower.
I'd check the rear one first. On automatic applications the rear vacuum assisted Mount is the most common to fail.
P
Old Dec 26, 2008 | 01:04 PM
zspy_007's Avatar
Thank you again. Greatly appreciated
One more question if you do not mind.
I was able to locate all of them except the rear mount.
Is it accessable from the top or bottom?
Thank you
Old Dec 26, 2008 | 01:16 PM
Mr Yamada's Avatar
Thank you
Look from underneath and be sure the metal actuating rod is still hooked up.
Old Dec 26, 2008 | 04:59 PM
P_Adams's Avatar
Thank you
As mentioned by Mr Yamada, it is accessable from the bottom. Very seldom does the mount control system have problems, it's usually the mount. While you're at it, inspect the others for any signs that they may have shifted or torn apart. I've seen more than one time where one failure begat another one, so check 'em all.
P
Old Dec 29, 2008 | 07:27 PM
zspy_007's Avatar
Thank you all for your help
I went under car today and checked it out.
It looks like it needs to be replaced but I can not see how it can be changed.
Area is so tight down there and It can not be reached from top.
Any recommendations?
Thank you
johnboy1313
Oct 17, 2013 10:16 PM
utterback93
Mar 17, 2013 12:31 PM
tkHBseries
Mar 23, 2006 05:58 AM
dmaestro3
Aug 9, 2005 09:06 AM
