Wheels, Tires, Brakes, and Suspension Wheel, Tire, Brake and Suspension Parts (Wheels, Tires, Coilovers, Lug Nuts, Camber Kits, Rim/Tire Tools)
Password:JDM Limited Edition BLACK Strut Tower Bars
Old Dec 24, 2008 | 09:44 AM
passwordjdm's Avatar
Default Password:JDM Limited Edition BLACK Strut Tower Bars
Our bars are individually hand crafted here in the states from 6061 aluminum. It's the strongest aluminum bars in the market and far exceeds the competition in both form and function. One of the biggest problems with most unibody cars that are bone stock from the factory is shock tower flex, a condition in which the shock/strut towers will flex under hard cornering resulting in a sloppy suspension feel.
Our bars were designed to eliminate that problem giving you a more solid feel to driving. With what we came up with, we were able to not only reach but we far exceeded that goal.
They are designed with a few goals in mind... form, function, and longevity.
About the bars... The mounting flanges are laser cut and formed from a SINGLE piece of 6061 T-4 aluminum and TIG welded individually for added strength and performance. The tubing is made exclusively for Password:JDM and is formed by a costly process known as extrusion from industrial grade aluminum which is then certified as 6061 T-4 to our exact specifications. The wall thickness (0.125") is far superior in rigidity to any other aluminum bars on the market to date. The coating is a high density epoxy coating proprietary to Password:JDM and is only available in Password:JDM Bronze and NOW in LIMTED EDITION BLACK!
Password: JDM REAR X 4PT in *BLACK* Available by PRE ORDER ONLY!
Old Dec 30, 2008 | 09:56 AM
Default Re: Password:JDM Limited Edition BLACK Strut Tower Bars
bump
Vtec04
Suspension & Brakes
Oct 29, 2017 11:16 AM
Zavy
Suspension & Brakes
Apr 14, 2008 02:46 AM
kellogg97rs
Suspension & Brakes
27
Oct 17, 2007 07:32 AM
daNk9
Apr 25, 2004 11:17 AM
