FS: Turbo Manifold - Downpipe - Intercooler - Charge Piping
I'm getting ready to start pulling the coupe apart for upgrades. Going to a 3in. Downpipe and Back-Door Intercooler.
Hi Tuned Performance B-Series T3 Mini-Ram A/C Turbo Manifold, Open Dump Tube, and 2.5in. Downpipe - Manifold and Dump Tube Ceramic Coated inside and out by HP Powdercoatings. Flanged for a B-Series using a T3 turbine and 38mm wastegate. In great shape. Has one scratch on the runner for cylinder one and a couple very minor scratches elsewhere. The downpipe is 2.5in. and has a flex pipe welded on. Has a 2-bolt flange and bolts up perfectly to a factory cat or aftermarket test pipe. Has a small dent on the bottom from the previous owner. All components are A/C compatible. I will not part out this package. Asking $550 shipped
Yonaka Motorsports Type 11 Intercooler - 26"x12"x3". In rough shape in my opinion. It was involved in an accident from a previous owner so it has a dent on the lower left side. It does not leak whatsoever. I've been using this intercooler for 10k miles at 15psi and never had a problem with boost leaks. The back is painted black and the front was recently repainted silver using VHT 2000* Silver Ceramic Coating. This is a $600 intercooler new. Asking $150 shipped
T-Rock Customs 2.5in Charge Piping - "One Piece" welded charge piping. Painted with a custom blended Summit White with a blue pearl added. Includes three silicone couplers and 6 T-Bolt Clamps. Flanged for a GReddy Type S/RS Blow Off Valve. In good shape. Has scuffs and scratches here and there. Most can be buffed out. As you can see in the pictures, they're not really noticeable. Asking $250 shipped
-Rob
-Rob
bb_one
Jan 19, 2007 07:19 AM
Griffin@Camtech
May 8, 2006 05:47 PM
Ricer4life15
Feb 25, 2006 01:41 PM
0ptimus prime
Welding / Fabrication
10
Mar 6, 2005 06:30 PM
0ptimus prime
Feb 17, 2005 09:55 PM
