Good ways to restore lost power?
Old Dec 23, 2008 | 06:22 PM
BAYxlude88's Avatar
Default Good ways to restore lost power?
I got my 99 lude a couple years back w/ 60k on it. I'm at 110k miles and i've notice that the car has gotten sluggish over the years..What are some good ways to restore lost power? I want to make a list of things i could do to restore the lost power and to make the car run more efficiently.
When i hit 78k i did: spark plugs, transmission fluid, timing belt, oil & filter change, etc.
What parts of the car should i clean or degrease? I think my EGR is clogged so i'm going to have to clean that. Should i change the spark plug wires? What else can i do? Feel free to list things to replace or clean that i should bring to the mechanic shop for.
Thanks.
Old Dec 23, 2008 | 08:36 PM
Kronn 98SH's Avatar
Default Re: Good ways to restore lost power?
Some common things that can reduce performance:
shitty or incorrectly-gapped spark plugs
shitty spark plug wires
dirty fuel filter
dirty fuel injectors
clogged or semi-clogged catalytic converter
dents in your exhaust piping
bad O2 sensor
other dirty/clogged/bad valves or sensors (i.e. EGR, etc)
engine sludge buildup
cylinder(s) not holding compression due to various reasons
Some common things not always considered that can also reduce performance:
thirty pound 19" chrome rims w/ spinners
one hundred pounds of new stereo equipment
a fat girlfriend/wife
thirty to one hundred pound STDs known as children
Old Dec 23, 2008 | 08:37 PM
Ventolin's Avatar
"thirty to one hundred pound STDs (aka children)"
LOL!
Old Dec 23, 2008 | 09:18 PM
twiztid00002's Avatar
i hope that wasnt your last oil and filter change
Old Dec 24, 2008 | 07:35 AM
bigz187's Avatar
Engine rebuild
Old Dec 24, 2008 | 10:23 AM
teambk8's Avatar
seafoam... dizzy cap
Old Dec 24, 2008 | 10:39 AM
preluderemis's Avatar
yeah i really hope so to...
-fuel filter
-air filter
-egr cleaning
-spark plug change should definitly help
is your check engine light on??
Old Dec 25, 2008 | 01:31 PM
LukieLuc's Avatar
easiest things that may help:
fuel filter
Seafoam
Spark plugs, and wires
Rotor cap, and rotor
Old Dec 26, 2008 | 12:22 AM
BAYxlude88's Avatar
Yes, my check engine light is on..
What are some good sites to buy parts from (spark plugs,spark plug wires,etc.)?
Do you guys use any engine cleaner? What product is best?
Any helpful DIY guides on maintainence?
Old Dec 26, 2008 | 04:19 PM
Kronn 98SH's Avatar
1. eBay for plugs & wires, go with NGK brand. hondaautomotiveparts.com for OEM parts
2. seafoam for internal use, power washer for external use
3. helminc.com
Old Dec 28, 2008 | 02:02 AM
BAYxlude88's Avatar
How do can you take care of the engine sludge buildup?
Old Dec 28, 2008 | 06:35 AM
kidcool1977's Avatar
SHAME ON YOU REBECCA!
Community Builder
majestic honda.com
Old Dec 28, 2008 | 07:38 AM
street_ride14's Avatar
By running your car for 10 minutes with 1 quart of oil in your engine. When you hear a grinding sound, this means the sludge is being melted/grinded away (this explains the smoke from the intake ). After the first 10 minute interval, add 1 more quart of oil in your engine and run that for 10 more minutes. After you add about 5 quarts of oil, then your engine should be practically sludge free. Oh yeah, don't forget to disconect your ECU completely during this process because looking at those flashing dash lights is always annoying. Have fun.
Old Dec 28, 2008 | 09:01 PM
BAYxlude88's Avatar
Is that method safe? Any other ways to remove sludge buildup? seafoam maybe?
Old Dec 28, 2008 | 10:49 PM
vinuneuro's Avatar
Everyone please ignore this post.
Old Dec 28, 2008 | 10:52 PM
vinuneuro's Avatar
Post what the cel code is. That most likely will lead you to your problem.
Replace spark plugs, spark plug wires, distributor cap and rotor. Buy the plugs from Napa, NGK V-power. Wires are cheapest from sparkplugs.com, you want NGK. Distributor cap and rotor just get from your dealer.
Old Dec 29, 2008 | 01:13 PM
...my motor feels slugish when my knock sensor isnt connected properly...might be a similiar problem...
Old Dec 29, 2008 | 02:30 PM
mattsnooz's Avatar
detergents at oil change shops kinda work to remove sludge. Seafoam in the crank case works wonders I hear. Make sure you follow the procedure to a tee and note that if your motor is aged and your seals are bad, cleaning your motor could show oil leaks where the seals were bad but being blocked by the sludge.
If you've maintained regular oil changes your seals would be fine though, but than again if you maintained regular oil changes sludge might not accumulate. Its a vicious cycle....change oil frequently and use synthetic if your motor likes it. Change it when it gets dark. Don't go by a Kilometer/mile or time period, thats for damn sure.
AlphaKennyWun
Feb 2, 2008 02:16 PM
soundfx06
Jan 16, 2008 03:24 PM
Beeda
Aug 3, 2006 08:14 PM
killaj12
Aug 14, 2005 12:28 AM
Cypher0117
11
Apr 24, 2005 09:26 AM
