OT: Best place to find Ingall's rear camber kit??
Old Aug 4, 2002 | 12:21 PM
ITR0962's Avatar
Default OT: Best place to find Ingall's rear camber kit??
What the title says. And yes, I did a search and found jack ****. Much help will be appreciated, thanks everyone!
Old Aug 4, 2002 | 12:31 PM
mingchi96
Guest
Posts: n/a
Default Re: OT: Best place to find Ingall's rear camber kit?? (ITR0962)
why would you want one?? just buy washers from autozone
Old Aug 4, 2002 | 01:34 PM
Zeus's Avatar
Hate mine with poly bushings... squeaked since day one... maybe rubber is better...
Old Aug 4, 2002 | 01:47 PM
Reid's Avatar
Global Moderator
Default Re: OT: Best place to find Ingall's rear camber kit?? (Zeus)
I had the Ingalls kit with poly bushings and it did squeak noticeably.
I didn't mind the noise though.
Just something to consider if you're in the market for these arms.
EDIT: Have you tried checking Import Parts?
[Modified by Reid, 12:48 PM 8/4/2002]
Old Aug 5, 2002 | 12:54 AM
ITR0962's Avatar
Default Re: OT: Best place to find Ingall's rear camber kit?? (mingchi96)
so basically you dont need the kit then??? just buy regular washers or what???
Old Aug 5, 2002 | 03:59 AM
Asahi's Avatar
first you shoudl ask . . What is your camber at currently? Do you really need them? Uneven tire wear isn't typically camber as much as toe.
Old Aug 5, 2002 | 10:03 AM
ITR0962's Avatar
Default Re: OT: Best place to find Ingall's rear camber kit?? (Asahi)
I just dont want my tires to wear out uneven. They look butterflyied from the rear! Dont you think I should worry about my tired wearing out so damn quickly??
Old Aug 5, 2002 | 10:11 AM
Asahi's Avatar
get the camber specs from an alignmnt rack
Old Aug 5, 2002 | 10:29 AM
PM-Performance's Avatar
check spcproducts.com . they have great camber kits, thats what run on my cars
Old Aug 5, 2002 | 06:40 PM
itr501's Avatar
Default Re: OT: Best place to find Ingall's rear camber kit?? (itr206)
i think u can get em at http://www.synchrobuys.com
Anthrolude
Apr 18, 2006 10:33 AM
jArceo
Mar 21, 2005 07:22 PM
LS Teg
May 10, 2002 10:18 AM
AllMotorITR
Dec 5, 2001 08:35 PM
