CRX w/b18C hood won't close
Old Dec 23, 2008 | 02:51 PM
tylojake's Avatar
Default CRX w/b18C hood won't close
I just completed b18c engine swap w/Hasport motor mount on my 90 crx si. And now my hood doesn't close, I would like to know if I can use jdm ZC hood.
Old Dec 23, 2008 | 02:57 PM
allgo88's Avatar
Default Re: CRX w/b18C hood won't close
yes you could pay 600 on a zc hood.or put washers under your hood hinges and raise it enough to clear.
Old Dec 23, 2008 | 03:08 PM
Deetz's Avatar
Crazy Honda Guy
You have a few options....
first off, a zc hood is only $200-400 depending, it'll work
Also could do an SiR style front end conversion
or, just buy a VIS cf hood. They can be had in zc, SiR-usdm fitment, or SiR- JDM fitment
Hope that helps
Old Dec 23, 2008 | 04:45 PM
EFRue57's Avatar
or another option, which i personally wouldn't do but have seen it done before, is to notch the framing on the underside of the hood where it is hitting. Like I said I personally wouldn't do it but if money is tight, then it is an option.
Old Dec 23, 2008 | 05:12 PM
SpeedSin's Avatar
I have seen others notch the "skeleton" of the hood for dual cam clearance as well. Its kinda janky but does work.
Old Dec 23, 2008 | 07:36 PM
tylojake's Avatar
Thanks for your advise.
Old Dec 23, 2008 | 10:05 PM
blaak-crx's Avatar
Weird that you can't close the hood. Hasport engine mounts are suppose to bring the motor down....
Old Dec 23, 2008 | 10:08 PM
Jas9848's Avatar
just notch the hood out underneath or spend money on a hood.
Old Dec 23, 2008 | 10:21 PM
BigDare23's Avatar
(shakes head)
Did you really need to make a thread about this?!?
Old Dec 23, 2008 | 11:46 PM
Ldo's Avatar
Ldo
Originally Posted by BigDare23
(shakes head)
Why can't he make a thread abou this?
Give the new people a break. Not everyone does enough motor swaps to know about hood clearance or hood types.
If a topic doesn't interest you, move on.
Dark_Teg
20
Apr 16, 2009 10:59 AM
VegaS10
Apr 4, 2006 10:23 AM
BrokdwnCrx
May 1, 2003 02:02 PM
xJ.SLOTHx
Apr 13, 2002 07:24 PM
