Detailing Auto Detailing and Concours
Best to clean dirty OEM calibers?
Old Dec 23, 2008 | 11:22 AM
Lightsped's Avatar
Default Best to clean dirty OEM calibers?
My car is a 00 Si. The car is mostly all stock. The brake calibers are filthy. Probably never been really cleaned in the life of the car. What is the best product to remove all dirt and stuff on the calibers? I am not interested in painting the calibers...
Thanks
Old Dec 23, 2008 | 01:09 PM
gator88's Avatar
Default Re: Best to clean dirty OEM calibers?
Pick your favorite degreaser and use it on your caliPers. I use purple power which is very aggressive and you do NOT want to get it on your paint. I dont know if your calipers are painted, but if they are, use something else like simple green diluted. Some agitation will most likely be needed for this, so I use my sisters if she pisses me off (joking, only toilet water one time when I was 8). Several attempts may be needed, but if you have wheels that show them, it will make your car look a lot better as I'm sure you know.
By the way, I am a motorcycle guy and have lots of cleaning stuff for them, and s100 cleaner works great and is actually for paint. I can get it at most motorcycle shops easily and the sponge that comes in the kit is awesome for scrubbing bug spots. I like it for degreasing around good paint. It is a good safe degreaser that should work well as long as you dont have raw aluminum around because this may slightly etch it just a bit. For this case, SHOUT laundry detergent is my choice.
Old Dec 23, 2008 | 01:34 PM
Lightsped's Avatar
Thanks for the help. My brake calipers have that silverish finish from Honda. 100% OEM calipers. Not modified at all.
Old Dec 23, 2008 | 02:39 PM
gator88's Avatar
No problem. If they are painted then try a few different things. I actually use purple power on my painted OEM silver/gray wheels without a problem, I have seen no side effects from it. I just dont let it sit long and keep it away from the actual good paint on the body itself.
Try Mean Green degreaser from dollar general or walmart. works good and is a few bucks for a small spray bottle.
Old Dec 23, 2008 | 06:52 PM
SoCal EJ1's Avatar
I used a couple cans of brakleen and a green scotchbrite pad -- worked alright.
Old Dec 24, 2008 | 07:57 AM
sonic em1's Avatar
I just use a small amout of simple green and a brush. Contact cleaner works good on brake parts as well.
Old Dec 24, 2008 | 08:00 AM
ecahatch's Avatar
Senor Miembro
...still looking for my calibers.
Captain Key!s
Detailing
Jul 8, 2010 05:18 PM
THEhomelessONE
Paint and Body
Jun 8, 2010 06:48 AM
EK9Tune
Nov 9, 2006 08:28 PM
DVS2000
Jun 19, 2003 11:17 PM
urbanlegend21
Jun 19, 2001 10:36 PM
