carbon hood replacement. Need direct bolt on
Old Dec 23, 2008 | 10:56 AM
acmoc's Avatar
Default carbon hood replacement. Need direct bolt on
Hi,
I'm looking to replace my old dented hood with a carbon one. Do any of you have any experience with the different brands?
Like I would like to know if the holes for the windshield washers are their, and if I will need hood pins and such, any type of modifications that might be needed etc.
Thanks.
Old Dec 23, 2008 | 11:30 AM
sde780's Avatar
Default Re: carbon hood replacement. Need direct bolt on
I'll sell you my carbon hood for $200 shipped
Old Dec 23, 2008 | 11:43 AM
knightsef-eg's Avatar
ill take that carbonfiber hood lol
Old Dec 23, 2008 | 11:57 AM
red_EF9Si's Avatar
All i gotta say is don't go with one of those no name brand hoods off ebay, stick to a trusted brand like VIS/Seibon. The one I got on ebay said "grade A" but it had yellowing all around the edges. It was brand new but looked like it had sun fading. Other than that the fitment was great. It's up to you if you want to use hoodpins and definately not a requirement as you should be able to transfer the latch from your OEM hood. I would personally advise against pins...but that's just me.
Old Dec 23, 2008 | 12:11 PM
sde780's Avatar
I said carbon hood, not carbon fiber. OP is talking about carbon mang
Old Dec 23, 2008 | 12:56 PM
acmoc's Avatar
Oops, I meant carbon fiber, I want to know if the holes for the windshield washer nozzle is their. I use those allot to remove the ice on my window.
It will be sa seibon from wek^sos.
thanks
Old Dec 23, 2008 | 01:32 PM
crx_si-r's Avatar
I have a VIS CF ZC style hood. I love it and fitment is awsome. The washer holes are there on mine but they are a little bit smaller than the ones in my oem hood, in order for me to make them fit I would have to drill them out a little bigger but I opted not to do that because I have the fear of spider-cracks in my hood
Old Dec 23, 2008 | 02:40 PM
GasDreamz's Avatar
Don't get pins, if you do buy something from ebay it make sure the seller is a dealer/store, and make sure they have 100% good feedback. I bought a CF hood for my Camaro off ebay and it's better material than seibon. I don't know about the washer holes cause my camaro has them in the cowl. I would say before you run out and buy one just look around and make sure that you get a good product in your price range, and make sure you'll be happy with it two weeks after you get it or you'll hate yourself later. And if you can afford it go to Meineke or Pep Boys and get it couted with their road guard plastic coating thing, you wont even see it but it will keep your hood from cracking if a rock hits it or something from being kicked up from the street.
Old Dec 23, 2008 | 02:53 PM
SpeedSin's Avatar
VIS was the best for a long time but, I had noticed the quality decline a few years back. Seibon is a very good brand.
Old Dec 23, 2008 | 03:01 PM
ALLxMOTOR EG's Avatar
Vietnamese!
no modification needed they all should have winshield washer holes VIS and Seibon are good depends on what you like
Old Dec 23, 2008 | 09:55 PM
blaak-crx's Avatar
Damn right Vis quality has gone bad! My expensive Vis Racing "carbonfiber" USDM SiR hood cracked/separated up front! Stay away from them! Seibon seems to have better quality.
Fixed it with clamps and Crazy Glue Gel:
Old Dec 23, 2008 | 10:08 PM
acmoc's Avatar
owhman, good fix though.
djeclipzjv
Welding / Fabrication
Jul 29, 2006 11:03 AM
MostlyR
Dec 19, 2004 09:43 AM
stpcivicguy
10
Feb 22, 2004 11:03 PM
Confuc1ous
Jun 22, 2003 12:23 PM
