J Mandrel Bend Help
Old Dec 23, 2008 | 08:43 AM
Turbo Wax's Avatar
Default J Mandrel Bend Help
Can one of you guys point me in the right direction here;
I'm looking for (1) 3" J Mandrel Bend pipe ( for turbo to intercooler) the problem I'm having is that I have not found one with very close ratio, (picture included) all the ones I have found are to wide for my needed application, I prefer to purchase it from someone from the forum to help a supporting vendor, Any help will be great either post here or send me a PM.
Thanks !
Old Dec 23, 2008 | 09:12 AM
silly sohc's Avatar
Default Re: J Mandrel Bend Help
What sort of CLR do you need?
Old Dec 23, 2008 | 09:42 AM
Turbo Wax's Avatar
I'm not familar with the different sizes but a 2" could be fantastic even a 3" may work, Im not sure if they even made them this close ?
Old Dec 23, 2008 | 09:52 AM
silly sohc's Avatar
No rarely they make/you will find a 3" in a sub 1:1 ratio. You may find it in a donut though
Hytech or Burns Stainless is your best bet for bend in 3" clr, it would be a 90 deg piece.
Old Dec 23, 2008 | 11:47 AM
CRMB's Avatar
OG Fabricator
Probably the tighest j-bend you are going to find is going to be a 4" radius which will be 5" between the legs. You could fabricate that assembly from a 3" OD x 3" RAD w/ (2) 90s and some straight though.
Old Dec 23, 2008 | 11:55 AM
Turbo Wax's Avatar
Thank you guys , I guess my idea to make this simple is out the door
Agtronic's Avatar
You can also pie-cut your tube to achieve the shape you need.
Old Dec 23, 2008 | 12:08 PM
Turbo Wax's Avatar
Agtronic thanks! I was just today looking at your thread about the shop and your work, some skills you have ! My idea was to do some of this fab work at the house with very little tools to save some $ thats why I had the J pipe on mind, cut it to lenght (which I have the tools) and be done with it, but it looks like Im running out of options and will have to pay someone to do this
Old Dec 23, 2008 | 03:20 PM
KFMRC's Avatar
http://www.woolfaircraft.com/ you will have to take 2 90's and wel them ut they do have 3od on a 3 centerline radius AKA 1D bend Your not going to find 180's because its very difficult to bend the material without it cracking/ tearing.
MERRY CHRISTMAS EVERYONE!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Dec 23, 2008 | 03:54 PM
Turbo Wax's Avatar
KFMRC
Thanks ! no wonder I din't find them for two days ! I should have come here and ask first,lol
Thanks to all of you for the help !
FIST321
Welding / Fabrication
Jan 16, 2008 02:28 PM
IMSLOW
Jul 1, 2005 08:05 PM
BEEYOND
Dec 2, 2004 04:15 PM
STEALTHMODECOUPE
Jul 22, 2003 06:43 PM
