Stuttering idle 1000rpm-1600rpm (Help?!)
Old Dec 23, 2008 | 12:08 AM
91rexhf's Avatar
Icon6 Stuttering idle 1000rpm-1600rpm (Help?!)
I got a 91 crx hf with d15b vtec and 5psi t3/t4 turbo with internal wastegate and when running at an idle it jumps from 1000rpm to bout 1600rpm with shitty take off and its constant, whether engine is cold or hot the idle still jumps. I also had oil in all 4 plug tubes, and leaking valve cover but hopefully gaskets and plug seal will fix that tomorrow.
Any suggestions, really need help thanks...
Old Dec 23, 2008 | 05:04 AM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
Default Re: Stuttering idle 1000rpm-1600rpm (Help?!)
check the fitv valve (behind the TB), IACV (back of the intake manifold), TPS (on the throttle body itself). one of those three is most likely your culprit.
Old Dec 23, 2008 | 01:46 PM
rangerxtrn's Avatar
yeah that definitely sounds like a vacuum leak, check all your SPwires and cap wires...
Old Dec 23, 2008 | 02:43 PM
gator88's Avatar
what do wires do for a vaccum leak there ranger? Jack ****.
Old Dec 23, 2008 | 03:19 PM
Eighty-Nyne's Avatar
Does it sound like this?
http://www.youtube.com/watch?v=7_Fl8...&feature=email
Old Dec 24, 2008 | 11:46 PM
91rexhf's Avatar
Icon3 Re: Stuttering idle 1000rpm-1600rpm (Help?!)
it sounds a little like that eighty-nyne but it a faster jump than that in the idle. And im gonna do the iacv and the fitv but there is a hose coming out of my fitv that i have no clue were it goes and my buddy said that could be causin it too. Also im pullin the tps code but i cant seem to find one anywhere without buyin a whole new tb
Old Dec 26, 2008 | 08:06 PM
rangerxtrn's Avatar
Oh, my bad, I guess the comma tripped you up, I'll put the word "AND" in next time and maybe you can figure that one out easier.
Why are there people like you that are always out to prove something on forums?
Do you have a "chip on your shoulder?"
Why the heck do you care enough to write sarcastic replies like that, that Do Not Help ascertain the guy's original question?
And just for saying that [what do wires do for a vaccum leak there ranger? Jack ****.] makes you look pretty stupid, and you misspelled v.a.c.u.u.m... vacuum leak= hoses on the intake poorly connected or not connected at all on the fittings / SparkPlug wires= loose connection of wires that lose contact temporarily during idle vibration as well as moisture infiltration of the insulating boots...
Old Dec 26, 2008 | 08:37 PM
user 47646775's Avatar
Yea and clean the hell out of them!!!!
luv2boost
Jun 2, 2008 06:33 PM
BME1986
12
Jul 13, 2004 04:57 AM
GreensleeperB16
Aug 5, 2003 07:41 PM
tegasaurus
Jan 20, 2003 08:24 PM
ponykillergsr
Dec 20, 2002 06:01 AM
