Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Need Your opinions on set-up..
Old Dec 22, 2008 | 07:45 PM
Too_Fast4u's Avatar
Default Need Your opinions on set-up..
Hi everyone,
Since this is my first ever post, I'd like to ask for your opinions on the following set up. I'd also like to bring to your attention that I intend to have this setup on 2006 Civic Si for racing purposes.
Thanks in advance and Happy Racing..
HONDATA Computer upgrade
HiTech K Series Header
Injen Cold Air Intake
Aim Data Management system
Mugan front splitter
Mugan rear wing
Exedy Stage 2 Race Clutch
Exedy Lightweight Race Flywheel
ROTO Black lightweight race wheels
WILWOOD big brake kit on front
Hawk race pads
K-Sport Adjustable coilovers
Rear Race Sway 25mm sway bar
Brake Master Cylinder
Old Dec 22, 2008 | 07:53 PM
kartman5's Avatar
Default Re: Need Your opinions on set-up..
For racing only?
Old Dec 22, 2008 | 08:15 PM
McBitchin's Avatar
hawk makes good pads. Why use the mugen bits? what kind of racing do you intend to do? If you just plan on auto-x might as well leave it stock other than the brakes/suspension work. Have you ever raced before? little more info plz.
Old Dec 22, 2008 | 08:16 PM
K5^'s Avatar
K5^
Brand New
What type of racing do you plan to do?
Are you going to leave the the stock catback?
Old Dec 22, 2008 | 08:18 PM
McBitchin's Avatar
lol at this thread so far, although it does look like he put a little effort into his modlist atleast.
Old Dec 22, 2008 | 08:28 PM
K5^'s Avatar
K5^
Brand New
In your original list you didn't list tires.
Originally Posted by Too_Fast4u
Hi everyone,
Mugan rear wing
Hawk race pads
My suggestion:
i/h/e of your choice
Hondata IMG
HFP suspension kit
Progress 22mm rear sway
hawk pads w/stock rotors
(light weight wheels of you choice; no bigger than 17" of course)
Falken azenis rt615's (225/45-r17)
DOT4 brake fluid
[gearbox choices are good]
Old Dec 23, 2008 | 07:04 AM
Too_Fast4u's Avatar
Thanks for the replies guys.
I'll go ahead and answer all Q's at once.
McBitchin: I'll be doing circuit racing and taking part in a 2.0L series. The Mugen bits are already fitted on the car. I still haven't made up my mind with wheels and tires, but I might go with 15" Enkie or Vulk.
K5: I'll be running a through pipe instead on stock catback.
Old Dec 23, 2008 | 12:04 PM
McBitchin's Avatar
I was under the impression a 15" wheel would not work on our cars, might want to go atleast 17's especially if you want to fit bigger brakes on there.
Old Dec 23, 2008 | 02:50 PM
ChargedSI's Avatar
Everything looks ok to me except you don't need a Stage 2 clutch unless your going forced injection. The stage 1 is good up to 205 ftpd of torque. You will be well below that with he set-up you list below. Why make it any more difficult to drive then you need too?
Old Dec 23, 2008 | 03:09 PM
vladd's Avatar
agreed. the exedy stage 2 was too much clutch for my turbo'd gsr; it's definitely WAY too much clutch for bolt-ons on an si.
Old Dec 23, 2008 | 05:14 PM
Too_Fast4u's Avatar
The maximum I can go according to rules and regs is 16", but I wanna make sure before buying the car. How would the 16's differ in performance assuming I'm having them fitted with Toyo 888..??
Old Dec 23, 2008 | 05:18 PM
Too_Fast4u's Avatar
Thanks you guys for the heads up. I'll surely be looking into that Stage one clutch instead...
Too_Fast4u
16
Jan 4, 2009 09:39 PM
square_1
44
Dec 28, 2008 12:11 PM
g2man
10
Jul 14, 2003 07:01 PM
cobalt
14
Mar 17, 2003 01:12 AM
DIRep972
33
Apr 12, 2002 08:36 AM
