Type R flywheel
So sense installing my clutch and flywheel, Ive had some drive ability issues. When I go to start driving from a stand still, the car has this weird vibration as I let off the clutch and give it gas. It doesn't seem to matter how I let off, fast slow, gas, no gas, revs, ect, it still vibrates until I get moving. After I get going though it engages kinda rough no matter how I shift. I have the CC stage four sprung clutch and the type r flywheel. Its only an 10.5 lb flywheel which isn't that light so I'm not attributing this issue to that. My crx had a 7.5 lb flywheel and I drove that just fine. I also don't think its the clutch because I researched the drive ability of it before I bought it. Could it be something with the installation or could it just be a bad mix? Also, only in 4th and 6th gear, when I let of the gas, the shifter moves accordingly. Like if I let of in gear, the shifter moves foreword and then back when I give it gas. Whats that about? Thanks guys.
When one of my old EG's started having the shifter move around when I would decel or accelerate, the tranny went out. Not to scare you or say that's what's gonna happen but maybe you should try and get it checked just in case, or ask a professional.
did they put the tranny back in correctly cause if your shifter is moving it could possibly mean the tranny is moving (i.e. pulling on the linkage) maybe the tranny mount isnt bolted properly?
RedlineShftr
Feb 19, 2005 08:17 PM
