FS: Edelbrock D16Y8 Turbo kit
Old Dec 22, 2008 | 05:13 PM
Hybrid96EK's Avatar
Default FS: Edelbrock D16Y8 Turbo kit
I have an Edelbrock turbo for D16Y8 for sale. DOES NOT have the Edelbrock intake manifold, extra injectors or the fuel computer. Everything else is there. I ran aftermarket 550's tuned on Crome Pro at 10psi. Car ran very strong. Exhaust manifold is painted VHT flat black, intake pipe was painted VHT aluminum. All charge pipes, intercooler, couplers, clamps, oil supply line, sandwhich adapter, fittings, oil return line, water lines, tial BOV, its all there. Even have a BRAND NEW from Edelbrock CARB sticker. Easily pass smog. The upper charge pipe with the BOV was modified to work with the stock Y8 manifold, fits perfectly! Bolt this on, slap in some injectors and tune it for easy HP. These kits retail for over $3,000. Asking $1,500 for everything. Turbo has approx 1k miles. very minimal shaft play, does not burn oil/water/smoke. No problems whatsoever. Clean kit!
Old Dec 23, 2008 | 06:23 PM
Didly's Avatar
Default Re: FS: Edelbrock D16Y8 Turbo kit
Where are you located? and.. what is needed to make this fit a z6?
Old Dec 23, 2008 | 07:49 PM
cteg92's Avatar
where are you located and do you still have the turbo kit
gsr.tuner
Jul 30, 2012 05:25 AM
Hybrid96EK
Jan 31, 2010 10:22 AM
Slipzee
Dec 19, 2006 10:38 AM
awalk2005
Oct 4, 2004 06:26 PM
1flossedteg
May 26, 2002 09:39 PM
