Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
08 lx check engine light came on after cold air install
Old Dec 22, 2008 | 02:02 PM
jmarine45lx08's Avatar
Icon6 08 lx check engine light came on after cold air install
I just installed my aem cold air intake on my 2008 2 dr lx and the next day my check engine light came on. Any ideas? Maf sensor issue? Or could it be the rain?
Old Dec 22, 2008 | 02:04 PM
FijiBlueFG2's Avatar
Road House
Default Re: 08 lx check engine light came on after cold air install
What kind of CAI? Did it have a MAF insert? If not, that is the reason.
Rain would not cause anything to happen, unless you drove through a puddle and subsequenntly hydrolocked your engine.
Old Dec 22, 2008 | 02:09 PM
its an AEM cold air kit i installed it myself and it uses the stock maf sensor from the stock kit
Old Dec 22, 2008 | 02:14 PM
Road House
It may just be the ECU is not adjusted to the increased airflow yet. Either drive around for a little bit, or reset the ECU.
Old Dec 23, 2008 | 07:38 AM
Zeusone's Avatar
probably due to the rain because it the air was very humid. reset the ecu by unplugging the battery for about a minute. make sure you have your radio code.
Old Dec 23, 2008 | 04:49 PM
MustangLX6.0's Avatar
have you checked the code yet? how does the car run. MAF codes should cause drivability problems
Old Dec 23, 2008 | 05:20 PM
JackSparrow's Avatar
Off topic,
OP, did you notice any performance gains from your cold-air kit?
(even though the check engine light came on?)
Old Dec 27, 2008 | 12:16 AM
COCA GROUND ASSAULT NY's Avatar
That happens alot when u change the airflow .. With anycar.... Ur really supposed to drive the car slow when u first install it so that the computer can read it correctly at first.... Try disconnecting the battery for a few minutes then connected again it should reset........
Old Dec 27, 2008 | 12:25 AM
h22 kid's Avatar
you should try to get the code first before doing anything that could cause more damage. once you have the code then start from there!
EduardoDC5
Jan 22, 2009 05:53 PM
bcaccord01
Mar 13, 2008 07:15 AM
DrewkCarrigan
Honda S2000
Mar 12, 2006 04:46 PM
ooooitswilson
Jul 28, 2003 11:02 PM
