Horizontal bandsaw blades.
Old Dec 22, 2008 | 12:25 PM
RickyLee53's Avatar
Default Horizontal bandsaw blades.
This might have been covered before.
I'm just wondering what people are using, and roughly how long they last.
On sch 10 i use a 14tpi carbon steel blade with a rigged up coolant supply and i get a fair few cuts from it.
If i use sch 40, and particularly on collectors its an absolute nightmare. It takes an age to cut and the blades are dull after just a couple of cuts.
I'm wondering if i should go to a 10tpi blade, different speed, or a bi metal blade?
Old Dec 22, 2008 | 02:05 PM
eclypzex's Avatar
Default Re: Horizontal bandsaw blades.
i just installed an HF bimetal blade i think its 10-14tpi and i made a few cuts with it yesterday and it cuts super smooth and pretty fast. then again, it was only 16ga tubing.
Old Dec 22, 2008 | 02:26 PM
c jackson's Avatar
threes
lenoxtools.com
Old Dec 22, 2008 | 03:22 PM
covertperformance's Avatar
I use a morse matrix II on my lame jet bandsaw. Made the bandsaw go from lame to a much nicer unit. Cuts nice and fast, and lasts a long time. My first and last blade I used for a couple months and i ended up seizing it and bending the blade causing it wobble so I replaced it before it was even worn out.
Old Dec 22, 2008 | 03:26 PM
Turbo Gav's Avatar
You did better than me Ricky at least you got an answer LOL
I also needed to know this.
Old Dec 22, 2008 | 03:31 PM
CRMB's Avatar
OG Fabricator
We use only lenox blades.
Old Dec 23, 2008 | 10:50 AM
RickyLee53's Avatar
I've been using Starrett in the past, but they've stopped making them for my size bandsaw now so i'm looking for a new supplier.
I've used 5 of the new type in the last couple of days.
There is a Lenox dealer in the UK so i've just sent them an Email.
Old Dec 23, 2008 | 11:58 AM
Agtronic's Avatar
I use a 14 TPI bi-metal blade, and it lasts for months. I routinely cut sch 10 pipe and 16G stainless tubing.
Old Dec 23, 2008 | 03:28 PM
KFMRC's Avatar
You should be able to find a mill supply that is capable of making or able to special order the blades to you spec. I have always found that 18tpi is a good cutting blade both from a speed point of view and also a long lasting one. It also works as a good all around tooth count so your not changing blades all the time. 14tpi will cut faster but will be more prone to ripping teeth off the blade. Bimetal blades will be much more expensive to buy but outlast a normal one 20+ times over in the right hands.
MERRY CHRISTMAS EVERYONE!!!!!!!
Old Dec 23, 2008 | 05:32 PM
redboost10's Avatar
wd40 does amazing things. i guarantee it will triple the life of the blade
Old Dec 24, 2008 | 09:57 AM
RickyLee53's Avatar
I use coolant, surely this will be better?
Old Dec 24, 2008 | 11:57 AM
redboost10's Avatar
i have no idea. our larger horizontal badsaw has a coolant system on it, but we dont run it, just use wd40
Old Dec 26, 2008 | 07:58 AM
eclypzex's Avatar
Lolol gheeeeeeeetto! Imma have to try it tho..
Old Dec 26, 2008 | 08:07 AM
redboost10's Avatar
haha, i guess it is
Old Dec 26, 2008 | 08:55 AM
Blackcatn2o's Avatar
Originally Posted by c jackson
lenoxtools.com
Thats a good company. my dad use to sell there products.
RJ#9
Welding / Fabrication
Jan 19, 2009 06:18 PM
turbojeesx
Dec 10, 2008 04:02 PM
ineedhelp
106
Sep 30, 2008 06:30 AM
Want2race
12
Dec 24, 2004 05:34 AM
