no fuel?
The fuel pump (main relay) is only energized when the key is first turned to the run position and during the time the CEL is on. Then it will be re-energized when the ECU senses the engine is turning. I mention this in acse you are trying to measure voltage at any other time. As for location, I don't know where it is located on your model. Sometimes they're above the hood release lever, sometimes they're next to the fuse panel.
thank you i didnt think main relay. seems fog lights went out, fuel dispersment went out, and my tranny s3 shift light stays on even though tranny is shifting just fine. then speedometer cable shot too, all acting up and happened round same time. odd to me so just put it off to age of car.
Agent Daimon
Feb 9, 2003 01:06 PM
