fuel system question.
Old Dec 21, 2008 | 06:44 PM
kojack_0's Avatar
Default fuel system question.
i am ready to purchase the following items:
aem fuel rail.
aem fuel pressure regulator.
walbro 255 hp fuel pump.
new fuel filter.
rc injectors.
my setup is a obd0 dohc zc on an 89 crx si.
ive been saving up for this, took me a couple of months but i have enough.
now on to my question, since ive never dealt with a fuel system before.
1. will a d16a6 [crx si stock motor] aem fuel rail and pressure regulator fit my dohc zc? or should i get the one for the d16a1 [89 integra motor]?
2. whats the preferred fuel injector size? 1000cc, 750cc, or 500cc? will i have to convert to obd1?
thank you.
Old Dec 21, 2008 | 06:49 PM
Twisted Image's Avatar
Default Re: fuel system question.
ummmmm are you buying all this fuel system stuf cause your boosting it? If not factory injectors will do just fine. at most GSR/LS injectors would be more then enough
Old Dec 21, 2008 | 06:53 PM
kojack_0's Avatar
hmm well im not boosting soon, i just figured since im getting all brand new stuff for the fuel system i might as well get injectors.
would you suggest just getting obd0 gsr/ls ones? or getting them serviced [cleaned]?
Old Dec 21, 2008 | 06:54 PM
kojack_0's Avatar
plus i just finished upgrading my suspension and braking system. so i moved on to the motor.
its a slow build.
Old Dec 21, 2008 | 06:57 PM
burningrex's Avatar
thats what'd do... the others might be a little bit over kill
Old Dec 21, 2008 | 07:04 PM
kojack_0's Avatar
alright. recap.
parts list:
fuel rail
regulator
fuel pump
fuel filter
gsr injectors
so no rc injetors what so ever.
but will a d16a6 fuel rail fit on a dohc zc?
Old Dec 21, 2008 | 07:12 PM
acmoc's Avatar
oil the threads on the fuel rail, if not they will leak because it won't be torqued well if not
som3on3_10
Apr 4, 2007 07:25 AM
big juan
Oct 29, 2005 06:59 AM
arielmalespin
Jan 4, 2005 11:33 AM
Shadow Templar
Jan 30, 2004 08:25 PM
