Transmission Question
I have an 89 EF Hatch with a bored out D15B7 Block with a D16Y8 head. The tranny is the 89 DX 4 speed manual. The car is currently running on a Chipped P-28 ECU. When i get on it and shift from 1st to 2nd it feels like the car dies. Is this because the P-28 ECU is for a 5-speed Tranny? What should i do? SI Transmission?
Do you really think it needs a tune for just having a stock head a built bottom end and all? Do you think that it needs Dyno time and all? I have the P-28 ECU. What chip and tune should i do? Hondata? Im not sure. Thank You
you need the 5spd tranny your ecu could use a tune but the reason it feels like it dies is because it have to drop so low because of the long *** gears in the 4 spd, get the 5spd si would be best
Thank You soo much. That is exactly what i thought. I just got ahold of an SI Tranny with new clutch. So i will be installing that and hopefully it will be faster and good to go. Thank You guys and i will keep you posted after the holidays how much different it feels. The only reason i thought the tranny and not the ecu is because in 1st gear the car is wild. It gets up and goes.
EG-SIXV-TEC
Engine Management and Tuning
Jan 3, 2014 07:57 PM
