Gauges on EF Hatch
Old Dec 21, 2008 | 12:10 PM
HondaBryan43's Avatar
Default Gauges on EF Hatch
Can someone please help. My temperature and Gas Gauge stopped working today. The speedometer still functions. I have no idea what happened. Thank You
Old Dec 21, 2008 | 12:39 PM
2slow4stock's Avatar
Default Re: Gauges on EF Hatch
Look in the fsm and find where the grounds would be. Maybe they came lose and or are corroded.
Oh yeah, do you have a tach? Does it still work? Check fuses also.
Old Dec 21, 2008 | 03:12 PM
I have an aftermarket tach and it still works and all. Do you have any idea where the ground would go and where it would be located in the back of the gauge cluster? If you know of any digrams that i could pull up and look at? Please let me know. Thank You soo much.
Old Dec 21, 2008 | 03:16 PM
01-0041's Avatar
What do you have:
Year?
Model?
Old Dec 21, 2008 | 03:26 PM
01-0041's Avatar
Just in case I don’t check this look at No. 1 (10A) fuse.
No. 1 (10A) fuse supplies power to many different components so look for other item to be non-functional.
Example:
Insert key an turn to (II)
Open your trunk and look at the cluster
What do you see?
If nothing you need to replace the fuse.
Old Dec 22, 2008 | 12:44 AM
Okay well i just thought it was the gauge cluster not functioning. Well now my turn signals dont work at all. So i have no idea. Please help. I want to drive it. Thank You soo much.
Old Dec 22, 2008 | 05:07 AM
Well thank you guys for your help once again. I got the turn signals fixed. I replaced the fuse and all of a sudden my clock and gauges started workign again. But i didnt think that it was all on the same fuse but i guess it is. Thank You
smashinhatch
11
Nov 28, 2012 03:57 AM
PacManSol
Apr 23, 2012 09:29 AM
emooheo
Jan 28, 2011 07:49 PM
shivic
Oct 28, 2010 10:56 AM
.BigSexy
Mar 13, 2007 09:26 PM
