Have a broken LS tranny? Have B series bolts/parts? LETS TALK!
Old Aug 4, 2002 | 06:31 AM
Will Albers's Avatar
Default Have a broken LS tranny? Have B series bolts/parts? LETS TALK!
needed:
LS or Si wiring harness
Several B series bolts, including those that are used to mount the tranny
to the block. I will need the nuts that hold the engine mounts onto the
spikes as well as almost every bolt on the outside of the LS tranny.
I need the plates that mount to the outside of the LS tranny used to
attach the mounts. If you have a spare busted LS tranny, lets talk!
I need an adjustable shift linkage or one that will work for my LS/B20
swap.
I need a B series alternator and starter
I also need an LS Intermediate shaft
Thanks! If you have any, let me know
Old Aug 4, 2002 | 10:06 AM
EF_LSVtec's Avatar
Default Re: Have a broken LS tranny? Have B series bolts/parts? LETS TALK! (Will Albers)
I'd check the classifieds forum too, if I were u...
Old Aug 4, 2002 | 11:58 AM
FredoTheChimp's Avatar
haha good luck, took me about 2 to 3 months to find the same exact parts.
Old Aug 5, 2002 | 01:44 PM
Default Re: Have a broken LS tranny? Have B series bolts/parts? LETS TALK! (Accord92sir)
Old Aug 5, 2002 | 05:02 PM
riceboy's Avatar
You won't believe it, but up until a month ago I had all of those parts, I threw them away, the mount, the bolts, everything, I had this big box of **** that was left over from ripping transmissions during the build of my car. Sorry man, and I would have given it all to ya for next to nothing. Next time I go to my storace I'll look and see if by any chance any of it didn't make it to the trash, if I see anything, I'll IM ya.
Old Aug 5, 2002 | 05:41 PM
VTECVillain's Avatar
I bought all those and a lot more hardware from Acura Carland for the 96 LS swap in my 91 CRX. I must've spent close to $100 in hardware and that's not including the driver's side and rear mounts. I had to buy tranny bolts, flywheel bolts, mount bolts, bracket bolts - so much crap!!! If you have or could get at least one of each, I would just go to a parts store and match them up because they will be much cheaper.
I have an extra 92 GSR shift linkage if you want to do the cut and weld method. I ended up buying a HASport linkage when I bought my mounts so I have no use for it.
averyvm
Jul 26, 2007 07:58 PM
paopao
Jan 18, 2004 08:06 PM
Will Albers
Aug 5, 2002 01:45 PM
Will Albers
Aug 5, 2002 01:44 PM
