96 ex accord clutch help?
Old Dec 21, 2008 | 06:00 AM
oj5joker's Avatar
Default 96 ex accord clutch help?
Yeah this morning I jus felt a big difference in my clutch then last night it sinks and when I push on it usually its stiffer(obviously) and doesn't engage till I hit the bottom which is basically the floor I asked some guy n he said I prob gotta bleed it cuz I might have air in my lines 2 problems how do I bleed my clutch and how would air have gotten in my lines?
Old Dec 21, 2008 | 06:12 AM
P_Adams's Avatar
Default Re: 96 ex accord clutch help?
IF you have air in the lines, most likely the reservoir momentarily sucked air. (the fluid was due to be replenished)
If by 'sinks' you mean that the pedel goes to the floor without disengaging the clutch, then you have a bad Clutch Master Cylinder. Bleeding it may temporarily mask the situation (via the introduction of fresh fluid), but the underlying condition still exists; corrosion of the cylinder's bore. This damages the cylinder bore's surface and doesn't allow the piston seal to conform and seal against the bores surface - thus the loss of pressure.
Mario Locatelli
Feb 7, 2014 11:36 PM
kniob
Feb 3, 2008 09:58 AM
crxricer66
Nov 3, 2007 01:44 PM
Perfourmance
Nov 16, 2004 11:08 AM
integra81
Sep 10, 2003 10:39 AM
