HID Wiring loom
Old Dec 21, 2008 | 12:42 AM
kyw3's Avatar
Default HID Wiring loom
I'm about to replace a pair of non-HID headlights to a pair of 98spec HID headlights and was wondering what sort of wiring I need to do to make this conversion work. I did use "search" but couldn't find any related and was hoping if someone can help me out on this. Many thanks.
Old Dec 21, 2008 | 12:44 PM
01_ITR's Avatar
Default Re: HID Wiring loom
https://honda-tech.com/forums/lighting-107/how-jdm-itr-hid-headlight-fog-light-wiring-2195061/
Old Dec 31, 2008 | 10:52 PM
kyw3's Avatar
Okay, after a bit of research and went through some of the threads I still couldn't get the complete picture of the installation. Is it just the extra wire that I need to add to the connector and where do I join the extra wire to? Hoping someone can shed me some light, much appreciated.
Old Jan 1, 2009 | 09:43 AM
platinum_rich's Avatar
Look at this link. Very helpfull. Pictures and everything. What problems are you running into?
Old Jan 1, 2009 | 12:16 PM
kyw3's Avatar
The wiring diagram isn't very clear (maybe just for me) the problem that I don't understand is that I didn't know where do you connect the extra wire to... after the addition of the extra wire to the connector.
Old Jan 1, 2009 | 12:25 PM
Spids5's Avatar
Don't judge or question
The high beam wire needs to be ran to the brown connector that plugs into the headlights. It is the middle wire(blue) on the bottom of the connector seen in this picture.
Old Jan 1, 2009 | 01:13 PM
kyw3's Avatar
Okay, thanks a lot for the help guys. I have just taken some pictures on the progress I'm at. So, basically from pic 1
and do I cut off the white connector (which connects to the HID 9006 bulb for non-HID headlights) and then join the wire to this connector? as in pic 2
I noticed that there are two wires for the white connector and I assume the black wire is for the ground? where do I join the ground wire to? Can anyone please check if I'm on the right track before I blow anything up... Thanks a lot guys.
Old Jan 1, 2009 | 01:32 PM
Spids5's Avatar
Yes the black is the ground wire and the other is power. I believe I wired it in with the other ground wires on the brown connector. Really you can connect it to any good ground though, you won't need to worry about floating grounds.
Old Jan 1, 2009 | 01:45 PM
kyw3's Avatar
Thanks Spids5, I will shoot off to the auto store to get a gold spade connector. Just to double check, so I will wire the black wire to the black wire on the brown connector right? Thanks in advance.
Old Jan 1, 2009 | 01:49 PM
Spids5's Avatar
Yeah the ground should be black but I would just double check this picture. The ground should be in the top right next to the HID.
Old Jan 1, 2009 | 02:35 PM
kyw3's Avatar
Got the gold spade now, will proceed to connect the wires now. Will you recommend to remove the battery for this installation? Will update how I get on, thanks for your help Spids5
Old Jan 1, 2009 | 02:40 PM
Spids5's Avatar
If you want just to be safe you can but the wire shouldn't be live if the headlights are off.
Old Jan 1, 2009 | 03:58 PM
kyw3's Avatar
Okay... I can't seem to remove the white part in the brown connector. From the previous thread it says grab it in the middle and pull it out lightly. I have tried it with large amount of force... is there anything I have done it wrong preventing me pulling the white connector out?
Old Jan 1, 2009 | 04:02 PM
Spids5's Avatar
No it just pulls out, sometimes it comes out easy other times it takes a little bit of force. If it does break it really won't hurt but it is nice to have it in. Try pulling from one side at a time to get it to come loose.
Old Jan 1, 2009 | 04:59 PM
kyw3's Avatar
Hey Spide5, here is a quick update. Yes, you are right and it helps to pull out the white part by altering the side first. Because it is impossible to remove any gold spade that is already in the brown connector, so this is what I have done to connect the ground wire from HID 9006 into the ground wire that is already in the brown connector. See pic below.
I have finished wired the HID one already. Just want to double check if this procedure is alright, thanks :D
Old Jan 1, 2009 | 05:18 PM
Spids5's Avatar
The gold spade connectors can be removed but you need a special tool. I cut one myself but what you did looks like it will work. Make sure you solder the wires and then protect them with electrical tape.
Old Jan 1, 2009 | 05:27 PM
kyw3's Avatar
Okay, I have just installed one of the headlight. There are some problems... The signal light is not working (also it is signalling at a really fast pace compared to normal) and the High beam H1 is not working too but the rest is working fine. Any idea on this or the headlights are broken? :O
Old Jan 1, 2009 | 05:30 PM
Spids5's Avatar
Did you have this problem before? To me it sounds like the fuse is blown on your high beam and a bulb is burned out for the signal. Either the front or rear being burned out will make it blimp faster than normal.
Old Jan 1, 2009 | 05:36 PM
kyw3's Avatar
No, I haven't had this problem before, because I just got this pair of HIDs. I believed it cames from a damaged vehicle but the headlights itself is in good condition. Do you think I should go ahead and install the other headlight to compare them?
Old Jan 1, 2009 | 05:38 PM
Spids5's Avatar
Yeah I would. The bulbs either came loose or are burned out if the fuses are good.
Old Jan 1, 2009 | 05:41 PM
kyw3's Avatar
Alright, I'll go and do the other headlight, finger crossed. Regarding to the fuse, where is that located?
Old Jan 1, 2009 | 05:43 PM
Spids5's Avatar
Under the drivers side of the dash I believe. If it is not there it is in the fuse box in the engine bay. Since you just got the headlights I would put money on the bulbs just being burnt out.
Old Jan 1, 2009 | 05:47 PM
kyw3's Avatar
Yea, I would have thought the high beam H1 bulb and the signal light burnt out. I hope it doesn't cost too much for replacement...
Old Jan 1, 2009 | 06:34 PM
kyw3's Avatar
Just a quick update Spids5, signal light is working fine now (you were right as it was burnt, so I switch over from my non-HID headlights to the HID ones) Sorry, just before it was the city light that was not working not the high beam H1 as high beam is working just fine. The problem I'm having now is that I have burnt 3 city light bulbs. This happens immediately as I switch on the lights. Is it because of the high voltage that is going through? Fuse?
Old Jan 1, 2009 | 06:36 PM
Spids5's Avatar
It sounds like something is wired up wrong. Does it happen for both the HID and non-HID? I would double check the wiring.
