gsr master cylinder on crx???????? HELP!!!
will a 4 door gsr master cylinder and brake booster fit on my 1991 crx? i see that one brake line is on the opposite side of the master cylinder will i have to run a new line? and the brake booster looks like its larger in diameter. will there be any clearance issues? i am upgrading to gsr brakes. thanks
i did the same but w newer gsr booster and master no mods of the lines needed at all and i suggest doin a proportioning valve too off a civic si this will make a huge difference
but just check it out
the one im using is from a 1995 4 door gsr. just like this one.
http://catalog.autohausaz.com/autoha...0053956ADL.JPG
Nope; didn't reflare anything. I was about to but stumbled upon a "M12 to 3/8" IFF adapter"; just thought I'd try since the M10 fittings are almost the size of 3/8" fittings....and it worked perfectly!
I had a couple of guys tell me that it was wrong, doesn't work(crossthreaded), will leak, etc....but I know when a bolt fits a nut perfectly as I work in the manufacturing business and the adapter specifically said it was for inverted flare fittings and was shaped so.
After looking up the PN online, I found out it's actually a M12/M10 IFF adapter and it's just mislabeled. I PM'd you the pic though; here it is again:
http://www.hydraulicstore.com/index....ms_detail&data[history]=&data[catalog]=1&data[itemcode]=1053206
Just bought mine today after what seemed to be endless searching.
If link does not work hydraulicstore.com part #1053206
alscrx
May 9, 2008 04:34 PM
underb00steg6
10
Mar 31, 2007 10:38 AM
ben_eg6
12
Dec 11, 2004 05:07 PM
