Do RSX-S brakes are the same as Euro CTR EP3?
I got a Euro/JDM type R and i would like to buy on ebay brakes, i wanted to know if the brakes on the RSX-S are the same as the EP3 type R.
Thanks
Thanks
well the base model rsx has the same size brakes as the EP3 except they are 5 bolt instead of the 4 bolts on the EP3 (02-03) the 04 and 05 have 5 bolts making them the same brakes...
The Type-S as the same same size rear brakes as the base model RSX and EP3 but the front has an 11.3" disc while the EP3 and base RSX have a 10.3" disc...
I am no sure on the Type-R but I know they use Brembo calipers... not sure on the disc size...
I myself will be just doing the Type-S front conversion and Rsx base rear conversion... because it will be cheaper getting the base model rear conversion compared to the RSX-S...
since were talking about breaks i was going to get brembo drilled and crossed rotors for my 05 type s. Online they said they are direct replacement from the stock rotors. I was wondering if its true if iits just a direct swap and for calibers i wanted to get the ones for the integra type r and will they be a direct swap out as well
the USDM EP3 got 4 bolts, the EURO/JDM EP3-type R got 5 bolts as the RSX...
the point is that in the states the parts of a EP3 type-r split between the EP3 SI and the RSX-S some of each car fits the euro ones...
so you say for sure that i can get rotors and pads for type s and fit them to my type r?
I'm doing this because parts for type R in Israel are expensive!
or you just can't get them.
thanks for the help
i really just wanted to get new rotors cuz mine were all rusted
and i have always liked the drilled and slotted ones just my opinion they look nice
Only here in the states did the ep3 get screwed...at least we have four wheel disc...poor em2 guys :\
