D16z6 Swap into 91 Si - o2 Sensor Question.
Old Dec 20, 2008 | 05:37 PM
Stunna MIKE's Avatar
Default D16z6 Swap into 91 Si - o2 Sensor Question.
So I just converted to obd1 ( www.rywire.com ) I now need a 4wire o2 sensor. I was wondering if this was any good, or if it would work at all. http://www.autopartswarehouse.com/de...USOS-4000.html
TIA,
Aaron G.
Last edited by Stunna MIKE; Dec 20, 2008 at 05:38 PM. Reason: Mis titled.. the title..
Old Dec 20, 2008 | 05:47 PM
Or should I just spend the money on one from Rywire?
Old Dec 20, 2008 | 06:29 PM
90crxdriver's Avatar
I've had a universal 4 wire O2 on my car for 6 month and even went turbo and it has worked fine. Just be careful when wiring it up, the O2 wires and the OBD1 wire colors are not the same but the instructions tell you what each wire is. That one should work fine.
Old Dec 20, 2008 | 07:10 PM
Cool. thanks a bunch.
Old Dec 20, 2008 | 07:39 PM
MOE@Hyper16Valve's Avatar
Just mod the ecu to take the o2 out of the program in the ecu,Get some type of chip that will
take out knock sensor and 02 easy to do,Depending what your doing???
I run a chipprd p28 which has no knock sensor and no 02 the 02 is there but for looks only i didnt have a 02 plug to cap it off hope thats some help...
Old Dec 20, 2008 | 08:20 PM
I have a z6 with Rywire obd1 conversion and Phearable chiped p28.
Old Dec 20, 2008 | 08:47 PM
Hey Moe, my car doesn't want to start after the obd1 conversion. How much would you charge me to get my car on the road.
Iron_Forrix
Dec 6, 2006 10:33 AM
icedemon
Apr 19, 2006 02:09 PM
Mr_Eg_Hatchback
Sep 5, 2005 12:06 PM
davidcrx89
Mar 22, 2005 04:43 PM
civtegra_hybrid
Sep 14, 2004 01:15 AM
