swap to vtec-e head?
Don't, the Z1 head is kind strange, the Z1 uses dished pistons, if you use a Z1 head on anything else it bumps the compression ratio up quite high, something like 12:1.
I couldn't tell you anything specifically for a D13, because quite honestly i've never seen one. The only reason I mentioned not to use the Z1 setup is because of its unusual nature causes it to be a problem pretty much everytime this sort of swap is attemped. Your best bet it to try to see if anyone from the UK knows anything about your engine, and/or what swaps on for a head as they got carbed D13s in some 5th gen civics.
zapzach
May 7, 2013 09:39 AM
