Help with spark plug tube seals
Old Dec 20, 2008 | 12:33 PM
Just me's Avatar
Default Help with spark plug tube seals
thanks
Old Dec 20, 2008 | 03:13 PM
waciii's Avatar
Valve cover gasket. You aren't messing with the head gasket unless you remove the cylinder head.
Don't know that model but my guess would be concave seal side goes up into the spark plugs holes in the valve cover. I feel pretty certain one way will fit better than the other and that will be a good sanity check.
Shouldn't be a problem to use the existing valve cover and check it after awhile. In the worst case replacing the valve cover if the scrapes become a problem shouldn't be too expensive.
Old Dec 20, 2008 | 04:16 PM
Just me's Avatar
problem solved thanks!
6poundsdaily
Jun 25, 2021 11:47 AM
eg6builtt3t4
Aug 28, 2008 03:30 PM
standbackimapro
Apr 29, 2006 05:38 PM
coupon
Jun 29, 2005 08:56 AM
CalvitoSol
Jul 8, 2002 12:03 AM
