bad sensor, code 10?
Old Aug 3, 2002 | 11:45 PM
ScottFern's Avatar
Default bad sensor, code 10?
I have gotten a CODE 10, or Intake Air Temperature code. I am not sure if I should replace the sensor or which one is best to get...because, the catch is, I am using a 97 gs-r harness on a b16a2. Should I get the gs-r sensor, or just replace the b16a2 one....I "think" they should plug into the harness fine.
Also, is the IAT located different on the b16a2, then the 97 b18c1. Could that cause a problem. I was told all the sensors match up easy. Guess I thought wrong ......
:confused:
Old Aug 4, 2002 | 12:12 AM
aeolus's Avatar
Default Re: bad sensor, code 10? (ScottFern)
The sensor from the B16A2 intake piping should work.Its just located in a different spot for smog purposes.As you can tell,the b16a2 doesnt have it on the Intake manifold like the older b16's
Old Aug 4, 2002 | 04:02 AM
EE_Chris's Avatar
Default Code 10 = IAT Sensor; defective or unplugged
Below are 2 charts that describe the IAT & ECT sensors resistance [with sensor connector unplugged] & voltage [with sensor connector plugged back in, black meter lead to a ground and red lead to the 'input voltage' of the sensor]. If the first time you measure the voltage on the one of the IAT/ECT sensor wires and it reads 0V, then the other wire is what you really want to measure [as the wire previous was the sensor ground].
I would suggest the voltage test first. The sensors input voltage and ground originate at the ECU. So if your reading a good voltage, then obviously the wiring is in check.
Temp F Resistance (ohms)
0 15,000
32 5,000
68 3,000
104 1,000
140 500
176 400
212 250
Temp F Volts
0 4.70
10 4.50
20 4.29
30 4.10
40 3.86
50 3.61
60 3.35
70 3.08
80 2.81
90 2.50
100 2.26
110 2.00
120 1.74
130 1.52
140 1.33
150 1.15
160 1.00
170 .88
180 .74
190 .64
200 .55
210 .47
Well isn't that a b*tch. It [the forum] removed all the spaces I used to seperate the columns...hopefully you can still discern what is what.
[Modified by EE_Chris, 1:03 PM 8/4/2002]
efyou999
May 24, 2012 12:21 AM
sh!ft
May 13, 2009 01:18 PM
Rykertest
Jan 5, 2009 09:40 AM
Silverhatch
Mar 20, 2006 11:56 AM
