need help asap......ef trans/clutch issue
Old Dec 20, 2008 | 09:47 AM
sykotik sol's Avatar
Default need help asap......ef trans/clutch issue
ok, i have a 89 honda civic si which has a 96 longblock in it but im unsure of what trans it is..
the code that came off trans is a cable L3-1311723 21 spline
and for some reason cant come up with what trans this is..can anyone help?
i keep ordering clutches for the wrong trans, 88+ is 20 spline..
please if anyone can help me resolve this issue id appreciate it..
Old Dec 20, 2008 | 12:04 PM
2point2's Avatar
88 is the black sheep year - 21 spline
89+ is 20
someone correct me if I'm wrong.
Old Dec 20, 2008 | 12:17 PM
IHEARTMYHONDA91's Avatar
89+ is 20
you are correct!
and if its the stock tranny that was in the car then its probably an si...
the si, dx tranny's are identical, the differance is in the final drive, the dx has a longer final drive.
and the hf tranny is all long gears.
try searching theres a **** ton of threads on here about the cable sohc tranny's
danktank
May 10, 2013 08:09 AM
Singlecam4dr
Dec 22, 2009 07:12 AM
sykotik sol
Transmission & Drivetrain
Dec 20, 2008 09:00 PM
Tyson
10
May 19, 2005 11:01 AM
Chronicsinners
May 17, 2005 12:34 PM
