map senser problem
Old Dec 20, 2008 | 09:30 AM
dan617's Avatar
Default map senser problem
i blow my motor and had a spear d15b7 motor lying around and trow it in just to have somthing to drive and now the check engine light for the map senser keeps going off and makes it run like **** i already tried swapping out the trottle body with the map senser and straight wired it to the ecu and tried that map sensor the goes on the frame you guys got any ideas why it would be messing up???
motor from my freinds 92 hatch and i put it in my 94 dx coupe
Old Dec 20, 2008 | 11:04 AM
mouab18c1's Avatar
are your wires loose?
Old Dec 20, 2008 | 06:29 PM
dan617's Avatar
no the wires are not loose and it was running fine with the ls in it any1 got any other ideas??? i think its gods way of telling me single cams are wack lmao
Old Dec 21, 2008 | 10:06 AM
mouab18c1's Avatar
Default Re: map senser problem
what ecu are you using? maybe the sensor is whack...SOHC are killers..
Old Dec 21, 2008 | 11:23 AM
dan617's Avatar
i got a obd1 ls computer and i tried a p30 , p28 and p72 and that didt help also i changed the sensor like 3 time
Old Dec 21, 2008 | 11:28 AM
mouab18c1's Avatar
why would you be running a dohc ecu on a sohc motor....try a stock ecu for that motor
Old Dec 21, 2008 | 12:21 PM
SOHCD16y8's Avatar
Did you switch the tps and map sensor plugs by accident.
Old Dec 23, 2008 | 10:29 AM
dan617's Avatar
yea i already tried switching the map senser and tps
and i dont see why having a dohc ecu on a single cam would make a diffence couse ppl chip p28 ecu's and use them on both dohc and sohc motors ... and yea i tried the stock ecu and it ran worse then with the ls ecu
Old Dec 23, 2008 | 10:51 PM
mouab18c1's Avatar
well the thing that people run chipped p28's on DOHC motors is that they burn a base map for the motor. With that done even though having a p28 ecu it could have a gsr base map on it, making it basically a gsr ecu...i say check your wires going to your ecu....i took out my VAFC from my car with a loose wire my Map Sensor came on..then figured it was my wire. rewired it and it runs like a champ again....
Dc_Ek
Feb 13, 2013 11:47 PM
FilbyBuilt
Oct 29, 2011 09:11 AM
JDMKid71
20
Mar 7, 2006 01:01 PM
jdm2teg
Jan 17, 2006 08:17 PM
ek9 ferio
May 31, 2005 07:49 PM
