rev limit
Old Aug 3, 2002 | 11:08 PM
boostedr's Avatar
Default rev limit
i was wondering, i had my canadian spec obd2 00 r cpu modded, the rev limiter is upped,up to what revs do you guys with the rev limiter upped have tested it? i have til 9700rpm (on the cluster) but i'm starting to be affraid i might break a retainer or something,and yes the motor pulls up to those revs in the first 3 gears in 4th and 5th going past 9300 with the stock cams and pulleys is uselless.
Old Aug 3, 2002 | 11:12 PM
01PYITR's Avatar
Default Re: rev limit (boostedr)
could you list your mods? I would like to know how your hitting 9300 in 5th gear and where?
btw stock has no limiter.
Old Aug 3, 2002 | 11:19 PM
Hacemuy's Avatar
Default Re: rev limit (01PYITR)
I believe that the rev limiter he is refering to is the fuel cut-off. If it is, then yes, stock ITRs do have a revlimiter.... but not a speed limiter.
Old Aug 4, 2002 | 07:31 AM
boostedr's Avatar
Default Re: rev limit (SOMEguyFROMoregon)
sorry i explained bad,my car is bone stock,so yeah no way in hell i'm hitting 9300 in 5th,soon tho as i have almost all the parts needed to install my big t-60-1 turbo,it will lag i know but when v-tec will it watch out.Yes i am talking about the fuel cut off not the speed limiter the r has none,so guys up to where do you guys have safely reved with the stock retainers?
Old Aug 4, 2002 | 07:38 AM
Eric R's Avatar
Why someone with a stock engine wants to do something like this???
That's useless. At that rpm you're not doing power at all!
Good idea to screwb up your engine, sorry
[Modified by '01ITR#950, 8:39 AM 8/4/2002]
neo1z's Avatar
are you saying that you are revving a stock R to 9300?
god help me.
thewrai6th
Aug 14, 2007 05:44 PM
johnzm
Nov 3, 2002 04:35 PM
4wsB21a
Feb 4, 2002 12:44 PM
