Z6 IM on A6 head... brake booster is really firm under load
I've put a ZC intake manifold on my D16A6, and it definitely pulls harder at 5000+ rpm!
BUT
Once I got out driving I noticed that at higher RPMs the brake pedal feels almost too firm and has little travel, but at idle its more soft like it used to be.
Is this something normal that I have been missing out on in the past, or is it something that needs to be looked at? The brake booster hose is plugged right in like it used to be... same valve I had on there before.
My guess is that the booster is not getting as much air at high load as it was before?
BUT
Do you have a vacuum gauge? If yes hook it up and check the vacuum at idle and when you are driving and having the hard brake trouble. There should be no difference in brake pressure with any different manifold as long as there are no leaks.
unlikely there is a leak just at high rpm's, there is just less vacuum at part throttle than closed throttle at idle.
You can try using brake fluid and spraying around the gaskets of the mani with the motor running and see if it changes rpm to find a leak.
think you mean carb cleaner! brake fluid would just make a mess
RACEPAK
Nov 23, 2006 01:33 PM
SwampThing
Sep 12, 2005 02:41 PM
swiftstyles
Jan 12, 2004 02:12 PM
