Is this the sign of bad oil pressure
Old Dec 20, 2008 | 05:13 AM
my_honda_'s Avatar
Default Is this the sign of bad oil pressure
Vtec does not work and leaking around the vtec selnoid would that be the problem? Would in need to get a new selnoid or what?
Old Dec 21, 2008 | 05:27 PM
preluderemis's Avatar
Default Re: Is this the sign of bad oil pressure
not the sign of bad oil pressure per say but i would definitly change the solenoid if its leaking...yes it would stop vtec from engaging...what motor is it????...odds are u can get a used solenoid from a junkyard or something
Old Dec 21, 2008 | 07:58 PM
honda_prelude_jay's Avatar
Depends on where its leaking. The screen is replaceable and has the gasket on it. The solenoid assembly sandwichs the gasket between it and the head. Unbolt it and see if the rubber seal is compressed and dry rotted out. Also unplug the solenoid and jump it (when its bolted to the head) straight from the positive post on the battery and see if it clicks. The solenoid only has one wire and its green and yellow. If it does click and vtec still wont engauge then further diagnostic tests will isolate the problem.
Old Dec 22, 2008 | 03:34 AM
my_honda_'s Avatar
yea its leaking out the side where the rubber gasket is. and i did the thing with the wires and it makes the clicking sound your talking about. would a new gasket make it stop clicking or a new slenoid. the motor is a 97 h22a1
THANKS FOR YOUR HELP
Old Dec 22, 2008 | 04:32 AM
lude98SH's Avatar
you want it to click that shows its working. Is everything tight ? If so change the gaskets, clean any old oil residue and recheck to see if it leaks.
Sk8NJ91
Dec 3, 2012 06:56 PM
miro_gt
Jan 26, 2009 10:55 AM
gsr.tuner
Nov 13, 2008 04:50 PM
anht
21
Jan 4, 2007 10:42 AM
b18c inside
Jan 16, 2006 12:05 PM
