Changing wheel bearings. Question about the hub
Old Dec 19, 2008 | 10:55 PM
akandok's Avatar
Icon2 Changing wheel bearings. Question about the hub
The car is a 93 Prelude with a 5 lug conversion. Usually the wheel bearing goes out because: a) '99 axles were not used or b) washers were not used with the 93 axles.
So we changed out the old bearing and right before pressing the hub back in, we noticed this.
Pics
Our question is, can this hub still be used? Or needs to be replaced?
Im thinking when the axle is in there with some washers, and its torqued down there should not be any issues.. Any suggestions?
Old Dec 19, 2008 | 10:56 PM
akandok's Avatar
Last pic shows that there is clearance between the hub and the bearing. If you keep pushing it further it fits on there very tightly.
Old Dec 20, 2008 | 01:30 AM
russlan44's Avatar
bump I want to drive tommorow
Old Dec 20, 2008 | 08:36 AM
russlan44's Avatar
Morning bump
Old Dec 20, 2008 | 02:59 PM
RaysBoomBoomLude's Avatar
whats the price\time involved with replacing it?
that looks like crap, IDK if its as bad as it looks.
but I replaced my rear wheel bearings\hub, and mine didnt look anywhere near that and mine had 100K miles.
Old Dec 20, 2008 | 03:03 PM
Duane_in_Japan's Avatar
I have seen so many problems, when I do bearings I just always order the hub also. Too many times the old bearing race does not come off easily so just press a new bearing onto a new hub and be done with it, parts cost more, labor costs less, same price in the end and all new parts.
Old Dec 20, 2008 | 03:15 PM
russlan44's Avatar
new hub runs around $137 and i looked up if i can use from another honda or acura, honda crv runs same hubs and same price
Old Dec 20, 2008 | 10:42 PM
russlan44's Avatar
night bump common ppl crime in
Old Dec 21, 2008 | 07:33 AM
Default Re: Changing wheel bearings. Question about the hub
Wow, it looks like I need to send hubs from Japan, its pretty rare in my experience that parts (OEM) are cheaper in Japan than in the US.
PreludeJunkie91
Jul 7, 2018 02:13 PM
alex1320
Mar 6, 2013 08:47 AM
dartonh22
Apr 2, 2012 11:55 AM
13HYBRID20
May 28, 2007 08:29 AM
Phatwhippin_CRX
May 9, 2002 08:11 PM
