Home made boost cut for crome
So basic crome has no boost cut... Feature that should be on every boosted car.
I was thinking about removing all the fuel when car gets to the boost you don't want it to exceed.
Or completly retard the timing along with no fuel.
What do you guys think? I'm not sure if doing this is safe or smart.
good point, it would work if you run big enough injector... But then if your wastegate decides to stay closed (vacuume line gets cut), I don't think richening the crap out of it isn't going to help you. It will just keep on going.
I wish I could just get it to misfire in a very safe way, but I can't think of one right now.
This is bothering me and I can't sleep.
How about setting ignition timing to like -10 degrees and getting rid of the fuel so that it doesn't backfire?
If you feel like spending a few dollars on a hobbs switch and a relay,you can hook that up to your coil to cut spark when boost hits a certain psi level.I have only seen it done on external coils but Im sure it's possible on internal as well.It's also adjustable depedning on which switch you buy
http://www.ka-t.org/overboost.php
I remember messing with all these features before, well at least I do now. Full throttle shift works, launch control only works if you add whole bunch of fuel and take away ignition timing at the certain spot in the map (make into antilag) but that completly messes up a spot in your map. I also remember the boost cut. **** short term memory loss! This is exactly why I stopped doing certain things.
hotimportcrx
17
Dec 5, 2005 04:52 PM
