Ball joint replacement
Old Dec 19, 2008 | 03:17 PM
esean93's Avatar
Default Ball joint replacement
well i got done with my swap couple weeks ago and found out that the ball joint threads r mess up and ill just need to replace them.i could work on it for all this time because of exams in school.does anybody have a idea of how to pop the ball joint out.im not a big guy just weigh 140.
Old Dec 19, 2008 | 03:40 PM
94EG8's Avatar
Seagull Management
pop the ball joint taper out of the LCA? or pop the ball joint out of the knuckle?
Old Dec 19, 2008 | 03:46 PM
esean93's Avatar
lca
Old Dec 19, 2008 | 03:52 PM
94EG8's Avatar
Seagull Management
hit the side of the LCA with a dead blow or ball pein hammer as hard as you can. Do not under any circumstances hit the threaded stud, even if you have the nut on it to protect the threads.
Old Dec 19, 2008 | 03:57 PM
esean93's Avatar
o wait im sorry i meant the knuckle.btw when i was getting it out of the lca(for the swap) i did hit the threaded part which is why i need to replace the ball joint.
Old Dec 19, 2008 | 03:58 PM
esean93's Avatar
also ball joint seperater made it a breeze.
Old Dec 19, 2008 | 04:12 PM
94EG8's Avatar
Seagull Management
With the knuckle off the car you can beat it out, you'll need to support it somehow though, and if its an aftermarket ball joint they usually have a snap ring you'll have to remove, OEM versions don't have a snap ring, they're strictly press fit. Press the new ball joint in, you can do it with a good bench vise and a hammer if you're carefull. (I have broken a good bench vise this way)
Old Dec 19, 2008 | 04:20 PM
esean93's Avatar
how did u support it while trying to pop it out?
Old Dec 19, 2008 | 04:23 PM
94EG8's Avatar
Seagull Management
I used part of an old bench vise, basically you need something thats bigger than the ball joint but smaller than part of the knuckle surrounding the ball joint. Its hard to explain, I wish I had some pictures.
Old Dec 19, 2008 | 04:30 PM
esean93's Avatar
yeah i get the idea.thanks man
Old Dec 19, 2008 | 04:42 PM
96redexcivic's Avatar
Hitting it with the hammer is something the backyard mechanic will do, and it's very dangerous. it can be costly to you and the car ( good people do good work )
Old Dec 19, 2008 | 04:45 PM
blkegcoupe's Avatar
From: ....................................................................................................
just go rent a ball joint press or go have a shop press it out and the new one in for you.
Old Dec 19, 2008 | 04:50 PM
great idea, for someone that has money, but I'll will go and rent it from local auto parts, it's free to my understanding ( use the right tools for the right equipments )
Old Dec 19, 2008 | 04:52 PM
esean93's Avatar
i woudl have a shop do it for me but i cant drive it to the shop because i cant put the hex nut on.ill try to pop it out and if cant ill just rent a press.where can rent a ball joint press though?
Old Dec 19, 2008 | 04:53 PM
esean93's Avatar
free?really?
Old Dec 19, 2008 | 04:57 PM
gstewart27's Avatar
I just used a big hammer, worked a treat
Old Dec 19, 2008 | 04:58 PM
Do have autozone there locally, they have the rental tools for free.
Old Dec 19, 2008 | 05:00 PM
I just used a big hammer, worked a treat.
Better save then sorry
Old Dec 22, 2008 | 03:14 PM
esean93's Avatar
Default Re: Ball joint replacement
those rental tools got me no where!i just had to use pb blaster and a hammer.right now it out all the way but the round thing(sorry i dont know what its called)where the axle sits on is blocking it from coming out.what should i do?
Old Dec 22, 2008 | 05:04 PM
esean93's Avatar
btw by out i dont mean its off loose its just up to the point where it hit the round thing(can someone tell me what its called at least?).
Old Dec 22, 2008 | 05:15 PM
esean93's Avatar
here is a pic of whats blocking the ball joint from coming out.
Old Dec 22, 2008 | 06:50 PM
esean93's Avatar
anyone?
Old Dec 23, 2008 | 02:37 PM
esean93's Avatar
nvm i just kept on hammering and the ring looking thing just poped out.god i feel stupid lol.
WhiteOnRice
Aug 18, 2024 11:11 AM
89efhatchcrap
Suspension & Brakes
24
Feb 17, 2009 10:36 AM
LaterApex
Suspension & Brakes
Oct 21, 2005 09:33 PM
Flamenco-T
Aug 21, 2002 11:49 PM
