how much HP & Tq. can a stock B-series Pressure plate can handle??
Old Dec 19, 2008 | 02:05 PM
b20vtech's Avatar
Default how much HP & Tq. can a stock B-series Pressure plate can handle??
okay, this is just for temp. use, im planing on turbocharging my ride and was wondering if the stock pressure plate will be ok under 300hp ?? thanks
Old Dec 19, 2008 | 02:07 PM
boostedcivicsir's Avatar
Mr. Badwrench
not much more than the engine produces stock. if it is temp, why worry?
Old Dec 19, 2008 | 02:43 PM
b20vtech's Avatar
wel i probably be broke after the turbo kit, so driving with a stock PP is my only option until i can get a stage4 CC kit.
Old Dec 19, 2008 | 06:22 PM
blackeg's Avatar
i assume you arent using a stock clutch with the oem pp?
run it with a puck disc if you have to use the oe pp for a short time is my advice.
Old Dec 19, 2008 | 07:08 PM
non-VTEC's Avatar
i think anything over 180ft/lbs is pushing the stock PP and clutch disk.
you are better off getting a cheap XTD clutch from ebay if you are on that tight of a budget. it will hold much more than the OEM clutch and is actually not half bad for the price. check out the XTD stage3.
Old Dec 19, 2008 | 07:37 PM
b20vtech's Avatar
I have a ACT 6 puck unsprung with stock OEM Flywheel and PP for the time being.....
Old Dec 19, 2008 | 08:51 PM
got wide's Avatar
you could get some really shitty tires and they might spin before the clutch does.
Old Dec 19, 2008 | 09:55 PM
b20vtech's Avatar
i have some 195 50 15 dorals, they spin as soon as i floor the pedal rolling on first gear at 10-15mph....
Old Dec 19, 2008 | 10:09 PM
ABK's Avatar
ABK
anything over 240hp on a drag radial will eat that clutch alive after few runs for sure.
Old Dec 20, 2008 | 12:36 AM
project dc2's Avatar
surprisingly we've put a few over 400 on a stock pp with a custom copper copper disc
Old Dec 20, 2008 | 12:39 AM
ABK's Avatar
ABK
was it tracked with that setup? That's amazing if that held together.
Old Dec 20, 2008 | 01:00 AM
yep. we install them in all motor cars all the same 200+ WHP
and turbo cars mainly street cars but many have seen slicks/hard launches too
Old Dec 20, 2008 | 06:01 AM
blaze the chemi's Avatar
How do you plan on tuning this car? Don't you think that the clutch/PP will heat up too much on a dyno and start slipping before tuning is complete? I'd find a used setup that will handle the torque you plan on producing. Try to find something that will handle at least 220 ft-lbs. THat' way you shouldn't have to worry too much until you save up dough to get the clutch you really need fresh!
Old Dec 20, 2008 | 06:15 AM
gc8dc95's Avatar
Just dont be out racing it on the stock equipment and it should last quite a while.
Old Dec 20, 2008 | 06:51 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
if you will be broke after the turbo kit, i would just be a little more patient and just wait until you have the money for the clutch. the clutch is a part of a "turbo kit" it just doesn't come in the box with the "kit". It's one of those necessities like Engine management that people need and tend to look over. You can't complete the setup don't start it until your ready. It will save you headaches in the long run.
Whats the big rush anyway? If it's for a race your just gonna burn it up anyway. I see no point to rush.
Old Dec 20, 2008 | 10:30 AM
ABK's Avatar
ABK
I might give the stock pressure plate/6 puck a shot on one car see how it holds up. Did you guys ever try this on d series?
Old Dec 21, 2008 | 02:21 PM
blackeg's Avatar
Default Re: how much HP & Tq. can a stock B-series Pressure plate can handle??
one of my friends did it on a vitara motor. 20+ psi, somewhere in the real high 200hp range. the car saw the track probably every other week for an entire season. mixed it up with 205 radials and 24.5" slicks. not to mention it was daily driven 15k miles. clutch never slipped.
projectdc2, the 200hp all motor cars you're putting these in are off the shelf 6 puck discs and just cleaned up oem pp's? i happen to be putting an act 6puck unsprung in a high compression b20 should be 180-200whp and im gonna use it for my daily driver
the.hamburglar
Oct 4, 2011 10:44 PM
Romo Pyro
Apr 20, 2009 07:31 AM
johnqt3
Sep 13, 2005 08:20 PM
Ideal R
Sep 2, 2005 12:13 PM
RTW DC2R
Oct 9, 2003 04:33 PM
