95 accord v6 swap
i have a 1995 accord v6 and im looking to do a motor swap with auto to manual conversion with future plans for a turbo upgrade. any suggestions on what motor would be ideal for this upgrade?
Well, your best bet would be the J30(98-?accord)/J32(TL) your current motor C27, can be converted to Manual out of the early 90's Legend(same motor). more info can be found on the v6 performance they don't make squat for the C27, as you have probably figured out, I'm currently looking at info for the J30 swap, I keep reading its been done, but no pics, I just need to get a hold of a 97ish CL3.0 to take some measurements, then its time to play
Swapping in a 6 spd j30 and turboing that sounds like a lot more trouble than it is worth. Considering the space limitations after the swap and the limited aftermarket support for that motor, you will not really be pushing too much psi.
If you are planning on turbo down the line, then just do an f/h series swap. The engine bay is already set up to accept mounts for f/h series. With the extra long space that v6 CD6 chassis provides, you will have plenty of room for a top mount manifold, huge turbine housing, and probably even space for a custom V intercooler/rad setup.
Ironically, swapping in a built 4banger makes sense.
It weighs far less
Parts are more readily available
It will accellerate quicker
The car will handle better
P
thanks everyone i think i will just swap in a vtec H22 but as far as turbo goes, i know to stay away from ebay turbo kits already but where would be a good place to get nice reliable full turbo kit that has everything i need to have professionally installed and ready to go. also i know its going to be fairly pricey which im prepared to pay as id rather do it right than half *** on cheap parts that break =\
http://www.turbospecialties-race.com/ or these:
http://www.spooledmotorsports.com/tu...Hybrid%20Turbo
Do your reseach carefully.
P
vche101
Oct 27, 2009 07:28 PM
