FS: [NYC-BX] Planet Audio VX900D 900w RMS Class D Mono Car Audio Amp - $120
Old Dec 19, 2008 | 07:52 AM
bxstylez's Avatar
Default FS: [NYC-BX] Planet Audio VX900D 900w RMS Class D Mono Car Audio Amp - $120
selling for $120usd FIRM... nothing lower!
originally paid over $300+ about 2 years ago! ...quick sale guys!
had the amp for 2+ years, and its still strong! ...never failed me!
great amp! ...just upgraded to JL 500/1 v2 amp for my JL W6
i accept credit/debit card as well... via paypal method (4% extra to cover paypal fees)
shipping via conUS... +$25usd
email me at: abz117 [at] yahoo (d0t) com
or call me: ( 6 46 ) 4 18 - 2 2 28 ***ALAN
hit me up on aim: chinointegraBX
Why this mono amp is a great choice:
Built just for subs:
This amp will run more efficiently than a conventional 4 channel or 2 channel amp. Mono amps are built with one thing in mind, and that is bass! They run more efficiently and they sound better.
Built low pass crossovers
This amplifier will last a really long time! They will also make your subs last a really long time. The low pass crossover is going to only allow deep bass to play out of your subs. The frequency of the crossover is completely adjustable so you can set the frequency to your taste. This will make your subs sound good and prevent them from getting damaged.
900w RMS!
This amp has a huge amount of power! The amp pushes 900 watts RMS to your sub(s). This is an extreme amount of power even if you are powering 3 subs. 900 true rated watts is enough to be heard from 2 blocks away.
Class D Digital Circuitry
This mono block amplifier is built with a class "D" digital power supply. This amp puts out more power than you would think. The reason for this is because class "D" amps are known to run more efficiently.
Trusted Brand Name
Planet Audio is known to be one of the best values on the car audio market for quality amplifiers and other car electronics. They make extremely high quality products which are tested very strictly. You can be sure the RMS ratings are rated at what the amp actually puts out. It is very important to buy from a trusted brand name who has a good reputation, because these days some newer brands rate the watts on their products differently and they right double or triple what the actual ratings are.
Features:
Efficient Class D Amplifier Design
900 watts RMS @ 1 ohm
650 watts RMS @ 2 ohm
800w RMS @ 4 ohm
THD at 1 Watt, 4 Ohm - 0.30%
THD at Rated Power - 0.50%
Signal-to-Noise Ratio, below rated power output - 100dB
Frequency Response, at 1 Watt, 4 Ohm - 15Hz to 150Hz (+/-3dB)
Frequency Response, at Rated Power, 4 Ohm - 20Hz to 250Hz (+/-3dB)
Damping Factor at 20Hz, 4 Ohm - 400
Crossover: Low Pass - 50Hz-150Hz, 24dB/Octave
Crossover: Subsonic (High Pass) - 15Hz-40Hz, 24dB/Octave
Bass Boost - 0 + 18dB
Phase Control (Switchable) - 0 to 180*
Input Sensitivity - 100mV to 2V
(2V to 8V COMPATIBLE)
Input Impedance - 10K-Ohm
Line Output Impedance - 100 Ohm
Peak Current consumption, at rated power into 1 Ohm - 175 Amperes
Dimensions (W x H x L) - 10 1/4" x 2 7/16" x 10 5/8"
lippstuh
Mar 30, 2008 07:55 PM
SiRay6
Jun 20, 2006 02:05 AM
hybridmyk
Aug 3, 2005 01:26 AM
boostedcvc
Feb 2, 2004 10:40 AM
