Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
!{{TUNERTOYS SMOKIN YR END SALE!! Turbo Plumbing Parts Fittings Flanges Oil Water}}!!
Old Dec 19, 2008 | 06:48 AM
TunerToys's Avatar
Icon3 !{{TUNERTOYS SMOKIN YR END SALE!! Turbo Plumbing Parts Fittings Flanges Oil Water}}!!
CHECK OUT OUR SMOKIN YEAR END SALE, CAN'T BEAT THESE PRICES EVER!!!!
MAP Adapter for Honda Engines - RETAIL $20.90 - HT SALE $18.00
These are an excellent item for installing your aftermarket MAP Sensor on your Honda engine. They can be installed facing driver or passenger side, and utilize a 1/8NPT port for connecting MAP sensors that use a pipe thread type connection. This includes Kavlico, AEM, and others. For the GM 3Bar sensors, we include a nylon fitting which adapts the 1/8NPT port to the same size barbed fitting as the 3Bar connector.
__________________________________________________ ________________
Stealthmode Oil Line Kits! - RETAIL $85.00 -HT SALE $75.00
Stealthmode Kits are the proven standard for plumbing your turbo's oil supply.
- Complete kit, No additional parts needed.
Water Line Kits for 14mm Metric Ports - RETAIL $49.90 -HT SALE $45.00
This kit contains all of the pieces for connecting to your turbo's water ports to your engine's cooling system. Instructions included.
Water Line Kits for 3/8 NPT Ports - RETAIL $34.49 - HT SALE $30.00
This kit contains all of the pieces for connecting to your turbo's water ports. This kit is a basic kit, which includes two styles of fittings for the turbo, hoses and clamps. You need to use the appropriate connectors based on where you decide to tap into the coolant system.
Turbo Drain Flanges (NPT Style) - RETAIL $15.99 -HT SALE $12.00
Convert your turbo's drain outlet to use standard plumbing fittings.
Turbo Drain Flanges (AN Style) - RETAIL $19.90 - HT SALE$15.00
Convert your turbo's drain outlet to use reuisabler AN fittings, for braided lines, etc.
Oil Take Off Fitting - RETAIL $21.10 - HT SALE $15.00
This is the fitting that made us famous. They are the perfect item for a simple low volume tap into your engines oil supply, for turbo oil feeds, or for pressure gauges. Just install between your block and factory sensor, and you now have two 1/8NPT ports for use with gauges, turbo oil feeds, and even LS/VTEC oil supplies.
-- Standard Policy Stuff --
We are subject to availability from the manufacturer for any of these products that are not in stock. If you have a time sensitive need, please make sure you let us know when ordering. Expedited handling is available on any item, for an additional fee.
These deals may or may not be available through our online store, as our promotional pricing may be different than our regular sale price. To take advantage of our promotional pricing, please send us an email at Sales@TunerToys.com, and we'll get you hooked up.
It greatly helps us if you include the listed part number for the item you want, when you contact us!
These prices do not include shipping. All shipments are sent through FedEx or UPS at our discretion. A valid tracking number with your address fulfills our end of the contract. We are not responsible for lost or stolen shipments. Our complete shipping policy can be found here - Tuner Toys Shipping Policy
Old Dec 19, 2008 | 07:33 PM
TunerToys's Avatar
Bump for great prices!!
Old Dec 27, 2008 | 01:20 PM
TunerToys's Avatar
Default Re: !{{TUNERTOYS SMOKIN YR END SALE!! Turbo Plumbing Parts Fittings Flanges Oil Water
Hurry up, the year is almost over!
Old May 25, 2009 | 03:52 PM
brayn951's Avatar
do you have some of those products for hx
brayn951's Avatar
and ifsohow much
TunerToys
Dec 5, 2008 07:39 AM
Flamenco-T
May 30, 2008 09:16 PM
