couple '00 gsr swap questions
I'm swapping in an 00 gsr drivetrain nto my 90 crx dx.
i got an obd1 converted harness with an obd1 jumper ready to roll.
which axles can i use besides hasport axles? are there any direct oem fitting axles i can use?
also i'm wondering which ecu i can use to get it running without a hondata. its going to have to be obd1 because i already got an obd1 jumper.
thanks
thanks
DA axles are a definite, go to an auto parts store and buy new axles for around $70 an axle. Or go to the junkyard and find a DA that still has axles in it, you just won't know the condition of them until you try them.
i dont think itll run a gsr motor without a hondata though, can someone confirm this?
WHAT ECU DO I NEED TO RUN THIS GSR IN MY CRX WITHOUT A HONDATA OR SOME TYPE OF TUNING SYSTEM?!?!
http://www.hondamarketplace.com/show....php?t=2354193
heres the fs thread, and ya a p 28 will
but you can ask around
butjust to let you know you can use a p28 out of a civic or a p72 from a gsr and they will run your motor eithor way you should get whatever you have done dyno tuned to get the best results, the p28 i have has been flashed w chrome and just has higher rev limit lower vtec engagment and diff fuel maps ... a litle more aggressive then stock
Black-Ty [EG6]
May 31, 2009 09:11 PM
firstgenrex
Mar 5, 2004 10:49 PM
