4x108mm on my DC2????!!!?!?!?
K I might be picking up a 95 DC for a dd. It just needs rims and tires. My girl has some stock focus wheels and tires that are mint, took them off her car brand new earlier this year. Problem is they are 4x108mm. Will they fit since they are damn close? Is there an adapter? I've found them for 114mm but not 108mm. Or can I slightly dremel out the wheels? This has crossed my mind, then just get them re-balanced. I need help asap.
Thanx.
Thanx.
Short answer: no.
You can't dremel wheels to fit. Just get your proper bolt pattern and hub size, it will be the easiest, cheapest, and safest thing to do.
There may or may not be an adapter but it will screw up the offset and it not worth if for stock focus rims.
-matt
-matt
just like neri said it isnt worth it. just sell those and buy something that fits perfectly. by the time you get adapters then it will already cost at least $100 and plus the adapter will most likely make your wheels stick out too much.
underpressure02
Jan 25, 2009 12:14 PM
1boostedcivic
Jul 11, 2007 03:00 PM
