What to put in clutch ? FLUID ?? please look
Old Dec 18, 2008 | 07:02 PM
krysted9354's Avatar
Default What to put in clutch ? FLUID ?? please look
ok i have always put brake fluid in my clutch, is that the fluid or what should i use ? manual.
{}{ what fluid should i fill ym clutch reservoir with ?
Old Dec 18, 2008 | 07:09 PM
lv6l's Avatar
I use regular brake fluid.
Old Dec 18, 2008 | 07:22 PM
ttt
Old Dec 18, 2008 | 07:32 PM
GYChris's Avatar
DOT 3 Brake Fluid.
Old Dec 18, 2008 | 07:59 PM
old man neri's Avatar
If you look on the lid of the clutch master cylinder it says 'dot 3'. That's what you should use. It also doesn't have to be the expensive stuff because it doesn't experience the high temps brakes do.
If you are going to add some you might as well flush the whole system. Takes about 15 min if you have a power bleeder.
Old Jul 4, 2018 | 07:53 PM
fgb000's Avatar
Default Re: What to put in clutch ? FLUID ?? please look
How much Honda dot3 will be needed to top It after switching master and slave cylinders?
how many Honda dot3 bottles do I need to buy please. Civic 98 sedan
Toonz18
Feb 26, 2018 11:54 PM
ccoake1
Honda Civic (2006 - 2015)
Jan 14, 2017 09:19 AM
mugenspoongsr
Aug 2, 2006 03:14 PM
John
Jul 28, 2003 04:24 PM
ragejed
Sep 12, 2002 10:59 PM
