90 siR primary o2
i have a 1990 siR. which o2 sensor is the primary one?. i have racing headers so there is no place to put one in there. there is a spot on my exhaust to put it but its before the cat its that correct? should i go with a simulated o2? car is running like straight **** any help would be great thanks fellas!
I suspect you are running OBD0 still. The PR3 and PW0 ecu's both use 2 O2 sensors. They both sample pre-cat. To make the engine run properly you must have both O2 sensors connected and working as they were designed. You cannot splice together, you can't run both sampling all 4 cylinders.
There are a couple of headers, inc the stock one, that will work correctly.
Your other option is to convert to OBD1 (distributor, jumper harness, ECU, 4 wire O2) and only run the 1 sensor.
The O2 sensors NEED to be mounted where the stock ones are located. If they sample from after the collector(where it goes to 1) your engine will not run correctly, it will run, just too rich or too lean.
If you have a 4-2-1 header that matches the same cylinders as the stock unit then you can add the bungs at the secondaries(the 2 in 4-2-1). But it needs to be the same as stock.
Ok, you asked which sensor is primary??? The one with the green square plug is primary.
The white oval plug is secondary and yes you need both in the upper section of your header. Cylinders 1&4 are primary and 2&3 are secondary. Install your o2 bungs as in my pic, also make sure they are 18mm bungs. Cause the sensors are 18mm. I know summit sells a metric and standard size. Also, the hole on your header thats next to the cat needs to be plugged. get a small bolt and plug it. USELESS on OBD0 cars.
Well welcome to the JDM b16a oxygen sensors. LOL, no problem. I have 8 full years of experience with honda's and counting. Its my passion!
Look out for my business soon, i am a Honda and Acura specialist. I will post once its opened.
This info is not completely correct.
Most 90SiR's (however, not all) have one pre and one post-catalytic converter signal.
On the dash will be an indicator light for the cat functionality. It will light up red, as well as throw a code 1 or 2. (or 43)
This setup is harder to fake, because the ECU is actually expecting a significant difference between sensor 1 and 2 to verify cat efficiency.
The picture ALSCRX is also a terrible setup. No offence dude. But that setup is only reading cyl #3 and #4 properly and maybe #2 a little and #1 not at all. Which is a shame because 1 and 2 are the most prone to fuel mixture and temperature issues.
so what do i do man?? please help me out. thanks
CAT efficiency wasn't measured until OBD2
Right pod, lower section, there are 2 lights on either side of the ajar indicators.
From the right two, the catalytic converter warning light is the top one.
Gauge cluster pinout can be found HERE.
Cat temp signal is the exact same voltage signal as any other 3V lambda reading.
I would translate it from my jdm manual, but my japanese is a little on the rusty side.
...anything else you wanted to dispute??
Anyway, to the original poster...
The best option would be to buy a $2 bung. You can get those from any muffler shop. I happened to buy mine from thermal R&D. (www.thermalrd.com)
Look for the merging point from runners 1+4 and 2+3 (that info was correct) and drill a hole, weld on the bungs at your convenience. I positioned mine simply left and right...because I had a thicker radiator and I wasn't looking for clearance issues.
If you can't get a bung, you can get bolts that have the same fine thread as an o2 sensor has. Cut one in half, and you're ready to go.
Remember that stainless steel headers are notorious for throwing o2 sensor codes because of heat dissipation issues. The same will happen if your sensor is too far down the exhaust line. 4-1 headers have no other choice but to mount the sensors all the way down near the cat...if you want to have any hope of an accurate lanbda signal. You can be lucky...but I had codes all the time.
In that case the best solution is to simply get a heated 3 or 4 wire sensor, and hook it up to any available power source. Preferrable an ignition switched source.
It's a couple of extra wires. But it's the neatest solution.
...or you can just chip the ECU and run open loop
Open loop is just jargon.
It means you are running the car with the o2 sensor disabled and bypassed. So the circuit is "open". Hence open loop, and closed loop for a functional o2 sensor.
You do kinda sorta really need an 02 sensor to tune/chip the car. But wideband sensors are usually heated, and will work fine all the way down the header.
