another code 43, changed o2 thrice...no dice yo
Old Dec 18, 2008 | 02:33 PM
CBEengineering's Avatar
Default another code 43, changed o2 thrice...no dice yo
ahhhhhhhhh
im still getting a code 43
only code that pops up. most people say it doesnt affect the way the car drives. but mine runs like total ****. most threads ive seen they just changed the o2 and every thing was fine.....not mine
pre dying:
91 si. d16y7(jdm zc) swap
things that were done to the car before the build v2.0
swap, ngk blues, mild tuck, xenocron obd0>1 jumper, p06 ecu, td-41u d15 obd1 dist, p08 intake manifold with b16 tb. map under dash, intake, header, stock fuel pump, tank etc.
ok it died one night stranding my wife and I and our 2 kids (2month old too) at a gas station. poped up code 43 and wouldnt restart
things I did when I tore it down.
completely stripped the harness and re ran everything (heatshrink, solder) new plugs where i could. new plugs/wires, timing belt water pump head gasket. full re-gasket. 3 different O2 sensors, brand new distributor, new iacv, fitv, gsr tb w/ tb mounted map. new tps everything within range. new FRIGGIN gas tank, lines where i could, new walbro 190 fuel pump, 3 regulators, im sure theres more
im about to pull my hair out
Old Dec 18, 2008 | 03:08 PM
Ldo's Avatar
Ldo
Isn't code 43 for fuel supply system or something? If so, changing the O2 sensor won't clear that. How are your fuel filter and fuel rail?
Old Dec 18, 2008 | 03:49 PM
oh forgot the fuel filter is new too. rail is fine. no obstructions.
Old Dec 18, 2008 | 04:03 PM
4drEF's Avatar
Keyboard Humorist
Seems there could be a lot of different things to make a code 43 pop.
Everything from vacuum leaks, IACV, O2, MAP, air filter, ECU, cracked injectors... anything that can affect fuel.
Only things you didn't seem to check out of the more common issues are the injectors.
May also want to try clearing the ECU between attemping to fix the problem.
Old Dec 18, 2008 | 04:27 PM
they are obd2 injectors and ive removed the resistor box
o i am every time.
Old Dec 18, 2008 | 04:39 PM
4drEF's Avatar
Keyboard Humorist
Have you pulled them since the problem to see if they cracked? Or tested them to see if any are stuck open.
I guess it would be best if you had a donor set to swap out and check.
Old Dec 18, 2008 | 05:01 PM
Ahknodd's Avatar
I'd check fuel pressure. That would be a good place to start. A bad O2 won't cause a car not to start, it may get bad gas mileage and may stumble a bit, but not like you're explaining.
Do the fuel pressure test, check your injectors and let us know what you find. Sorry man, hate when cars do this.
Old Dec 18, 2008 | 06:10 PM
4DRmafia's Avatar
Like I said, I'm thinking it has something to do with the injectors. You said it runs like ****? Maybe the injectors are not doing it's job. Could be bad or cracked.
Old Dec 18, 2008 | 06:29 PM
kojack_0's Avatar
try a different ecu.
cause it says code 43 has 3 different meanings, fuel supply, and 2 other things that lead to o2 circuitry.
dont know what that means. but id try a different ecu.
Old Dec 18, 2008 | 06:38 PM
90crxdxY8's Avatar
when i swapped in my y8 i got code 43 and i did the same as you filter checked injectors... it turned out i wasnt getting enough fuel pressure so i changed my pump to a walbro.. and a adj external regulator and voalla all is good now.. ps changin the 02 didnt do a damn thing
Old Dec 18, 2008 | 07:55 PM
4DRmafia's Avatar
He has a walbro pump.
Old Dec 18, 2008 | 08:06 PM
90crxdxY8's Avatar
sounds like my issue then i pinched the fuel return line and it ran great thats how i knew i needed more pressure
Old Dec 19, 2008 | 11:18 AM
i cleared the ecu. restarted with the line pinched. ran great with the line pinched. but it still threw the code 43. so i put a p28 in it and let it run for a while and it only threw 21 and 22 immediately. so it looks like the ecu. going to try my bros p06 when he gets off work. another thing i tested for voltage at the o2 plug with my p06 and i didnt get anything. didnt test with the p28 cause i had to put the plug back thru the harness hole in the bottom of the fire wall. but no 43 out of the p28
Old Dec 19, 2008 | 11:42 AM
iwanttokillgod's Avatar
could be the main relay or if there is a small pin hole in any line it could throw the code also
Old Dec 19, 2008 | 11:57 AM
new main relay. pin hole in what line, fuel line?
Old Dec 19, 2008 | 12:02 PM
the problem occurred with the obd0 injectors. i swapped the afterwards and its still there
Old Dec 19, 2008 | 02:58 PM
put in my bros ecu with the line clamped ran fine.
93grayeg
10
Oct 17, 2011 08:07 PM
93grayeg
10
Jul 30, 2011 11:35 AM
egvtec
12
Jan 3, 2009 09:24 AM
slowcrxsib16
Dec 20, 2008 09:32 AM
white90rexsi
25
Sep 2, 2007 05:16 PM
