question about egr valve
Old Dec 18, 2008 | 02:13 PM
iwanttokillgod's Avatar
Default question about egr valve
my question is how long should it take for the egr to code i have a 93 del sol si with a h22a1 and a usdm p13 ecu so everthing is stock the only thing not wired in is the egr valve so i want to check codes just to see whats going on and it dosent throw a check engine light. i have not driven the car i will just start it up and let it idle any info or help will help
Old Dec 18, 2008 | 05:26 PM
srmofo's Avatar
Im not exactly sure what your asking? but if you haven't driven the car then it might not throw the egr code. the car doesnt use egr at idle, WOT, or if the engine is not warmed up yet....so if it hasnt been driven it might not recognize theres a problem yet
Old Dec 18, 2008 | 05:38 PM
thats exactly what i wanted to know that you very much
Old Dec 19, 2008 | 06:19 PM
tech7427's Avatar
if there is an open in the circuit the cel should come on right away. regardless of egr lift and flow.
Old Dec 19, 2008 | 10:58 PM
SOHC_4dr's Avatar
the H22 doesn't even have a EGR. the 90's VTEC engines didnt have EGR's because thats what VTEC helped with. your Z6 in your Si wouldnt have an EGR either.
Old Dec 20, 2008 | 12:19 PM
tech7427's Avatar
the hell it doesnt have an egr valve.
i had an h2b integra, obviosly a h22 motor, it had an egr valve on the intake manifold.
Old Dec 20, 2008 | 03:00 PM
SOHC_4dr's Avatar
i looked at a pic and dont see it. where do the tubes for it run??? i have always seen them off the header and i dont see any on the H22.
Old Dec 21, 2008 | 06:26 PM
tech7427's Avatar
Default Re: question about egr valve
they do not have tubes. the passages are built into the intake manifold and head from the exhaust side.
Old Dec 21, 2008 | 08:28 PM
what the hell are you talking about h22's defiantly have a egr valve anyways, also why r u mentioning a z6 motor when i wrote i had swapped the 93 si to a h22
Old Dec 21, 2008 | 09:55 PM
SOHC_4dr's Avatar
i said they didnt because i havent seen them. most VTEC engines dont have them and didnt realize the H22 did. you 93 Si came with a Z6 factory correct? it didnt have an egr correct?
iwanttokillgod
Dec 18, 2008 06:22 PM
Unidentified
Sep 23, 2006 10:33 AM
TheAccordGuy
May 28, 2006 09:46 PM
dayaftertomorrow
Feb 26, 2005 10:11 PM
munscher
Nov 24, 2002 04:48 PM
